[Qgis-user] Save log to file via cmd
Christoph Jung jagodki.cj at gmail.com
Wed Mar 10 13:15:27 PST 2021
I tried to find any documentation about this command for Unix/macOS to reproduce this issue on another OS. Does anybody know, how I can use the command „qgis_process-qgis-ltr“ in the macOS-terminal or is this a Windows-only feature? My terminal does not recognize this command.
Regards,
Christoph
> Am 10.03.2021 um 08:43 schrieb Karl Magnus Jönsson <Karl-Magnus.Jonsson at kristianstad.se>:
> No, unfortunately not. I guess it is a bug that has to be reported.
> Karl-Magnus Jönsson
> -----Ursprungligt meddelande-----
> Från: Christoph Jung <jagodki.cj at gmail.com>
> Skickat: den 9 mars 2021 09:33
> Till: Karl Magnus Jönsson <Karl-Magnus.Jonsson at kristianstad.se>
> Kopia: qgis-user <qgis-user at lists.osgeo.org>
> Ämne: Re: [Qgis-user] Save log to file via cmd
> Thank you for you answer, Karl. Did you found another solution to create such log files? I tried to write the output of the command to a file via “qgis_processing-qgis-ltr [...] > path_to_logfile.log”. But only the input section will be written to this file, not the result section.
>> Am 08.03.2021 um 17:03 schrieb Karl Magnus Jönsson <Karl-Magnus.Jonsson at kristianstad.se>:
