[Qgis-user] Access database via cmd
    Karl Magnus Jönsson
    Karl-Magnus.Jonsson at kristianstad.se
    Fri Mar 12 03:13:44 PST 2021
Hi!
Good news! Thanks. I wonder if you tried to connect to a PostGIS database from command line. As a parameter. In graphical mode it works and looks like:
'postgres://dbname=\'geodb\' host=servername port=5432 user=\'user\' password=\'pwd\' sslmode=disable key=\'UNIK\' estimatedmetadata=true srid=3008 type=PolygonZ checkPrimaryKeyUnicity=\'1\' table=\"pri\".\"byggnad_\" (geom)'
If it's possible in cmd I don't know how to format it properly.
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För Christoph Jung
Skickat: den 12 mars 2021 06:50
Till: Nyall Dawson <nyall.dawson at gmail.com>
Kopia: qgis-user <qgis-user at lists.osgeo.org>
Ämne: Re: [Qgis-user] Save log to file via cmd
That’s great, Nyall. Thank you for your effort :)
Regards,
Christoph
> Am 11.03.2021 um 23:46 schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On Tue, 9 Mar 2021 at 00:41, Christoph Jung <jagodki.cj at gmail.com> wrote:
>> Hello everyone,
>> I created a model and added the function “Save log to file” at the end of my model. If I start the model directly in the QGIS application, it works fine (the log file will be created and contains information).
>> Now I want to call this model from the command line to schedule this task. I created a batch file, setting up the osgeo4w environment and calling the model via qgis_processing-qgis-ltr in this script. The log file will be created, but there is no information in it. There is no error message or something else in the command prompt too. Does anybody has an idea how I could get the information in my log files when I call my model via command line?
> Thanks, fixed here: https://github.com/qgis/QGIS/pull/42208/files
> Nyall
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
