[Qgis-user] Create circle with diameter in QGIS
gam17 at riseup.net
gam17 at riseup.net
Mon Mar 15 01:01:51 PDT 2021
Hi, look at QAD plugin...
> With Geometry Shapes complement you can draw a circle / oval just with
> a center point and setting radius (x) and radius (y)
>> El 12 mar 2021, a las 14:21, qgis-user-request at lists.osgeo.org
>> escribió:
>> Message: 1
>> Date: Fri, 12 Mar 2021 12:37:40 +0000 (UTC)
>> From: Madeline Krohn <m2.krohn at yahoo.de>
>> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Create circle with diameter in QGIS
>> Message-ID: <783378190.318358.1615552660204 at mail.yahoo.com>
>> Content-Type: text/plain; charset="utf-8"
>> Dear QGIS Team,
>> I would like to create a circle whose diameter is 75 metres. I am
>> using QGIS version 3.16.3-Hannover.
>> My procedure so far has been like this:1. create a new shapefile
>> layer -> geometry type: polygon2. in edit mode of this layer: add
>> circle with centre and another point--> How can I change the
>> radius/diameter of the circle afterwards or is there another
>> possibility to create a circle with diameter directly?
>> Thank you very much and best regardsMadeline
> Qgis-user mailing list
