[Qgis-user] raster layer combination
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sat Mar 27 15:07:00 PDT 2021
Also, before sending this to spss, I would investigate if the statistics you plan to use are resistant to the effects autocorrelation.  If not, you will violate the fact that each sample need to be independent of each other.  I would look for spatial statistics.  You can look at GeoDa, R spatial packages...
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 27 mars 2021 à 15:18, Christine <geo.guide at web.de> a écrit :
> Dear Milena,
> have a look at the tool  'Sample raster values' in QGIS Geoprocessing: This
> algorithm creates a new vector layer with the same attributes of the input
> layer and the raster values corresponding on the point location.
> If you sample the values of your raster layers for your given points (large
> airports or outbreak location points) you should get what you want. To
> complete the parameters for your regression analysis you should probably
> also perform a distance analysis, perhaps with the tool 'Distance to nearest
> hub (points)', but I never used this tool.
> I would try the sampling of the rasters and a distance analysis focusing
> both on the airports and the outbreak location points as well. I mean
> approach the regression from both sides.
> Regards, Christine
> Milena Muehler wrote
>> ... I have several raster layers (population density; livestock density;
>> mammal density; etc.) and two text layers (so I've imported two csv files
>> with longitudes and latitudes into QGIS and now I have points about the
>> location of large airports and location points where there was a zoonotic
>> infectious disease outbreak).
>> My intention is to „combine“ all layers and to get all the values under
>> this specific point of an outbreak. So that I have the exact value of the
>> population density, livestock density ans so on where the outbreak
>> occurred. I guess I have to make the calculation within a certain vicinity
>> though.
>> In the end I want to have a file as an output with values to make
>> regression analysis in SPSS.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210327/dbbe64be/attachment.html>
