[Qgis-user] QGIS-Server Layer Order
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Mar 31 10:13:15 PDT 2021
Hi Andreas,
Thank you very much for your reply and help.
I appreciate it.
Kind regards
Julierme
On Wed, Mar 31, 2021 at 1:17 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Julierme,
> It is the client that requests a certain layer order, not the server.
> Unless you request a group layer/top level layer.
> You find the information on the initial layer order in the
> GetProjectSettings response:
> https://docs.qgis.org/3.16/en/docs/server_manual/services.html#server-wms-getprojectsettings
> The information of the GetProjectSettings response can be parsed by the
> client and used to generate an appropriate GetMap request with the correct
> layer order.
> Hope this helps,
> Andreas
> On 2021-03-31 18:07, 1520 gis wrote:
> Hi developers,
> I have tried to change the QGIS-Server layer order using QGIS Desktop
> Layers Panel and L.TileLayer.WMS (Leaflet) zIndex options. None of them
> could change the layer order. It seems that QGIS-Server always serves from
> bottom to Top: raster images, polygons, lines and points by default. Is
> there any way to change these settings?
> Kind regards
> Julierme
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210331/de23be8c/attachment.html>
