[Qgis-user] QGIS-Server Layer Order
Andreas Neumann a.neumann at carto.net
Wed Mar 31 13:26:12 PDT 2021
Hi Julierme,
The GetProjectSettings XML response provides an element called
<LayerDrawingOrder/> where you can find the initial layer order of the
QGIS project. Based on this, you can then formulate the GetMap request
with the "LAYERS" parameter. The order you specify after LAYERS= defines
the layer rendering order.
Greetings,
Andreas
On 2021-03-31 22:16, 1520 gis wrote:
> Hi Andrea,
> Did  you mean to add [1] LAYERDRAWINGORDER=... as a parameter in WMS
> request?
> [1]
> <LayerDrawingOrder>OSM,biomas,ufe,rodovias,aerovias,rbmc,maregrafos,cbers4</LayerDrawingOrder>
> Kind regards
> Julierme
> On Wed, Mar 31, 2021 at 2:13 PM 1520 gis
> <juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Andreas,
> Thank you very much for your reply and help.
> I appreciate it.
> Kind regards
> Julierme
> On Wed, Mar 31, 2021 at 1:17 PM Andreas Neumann <a.neumann at carto.net>
> wrote:
> Hi Julierme,
> It is the client that requests a certain layer order, not the server.
> Unless you request a group layer/top level layer.
> You find the information on the initial layer order in the
> GetProjectSettings response:
> https://docs.qgis.org/3.16/en/docs/server_manual/services.html#server-wms-getprojectsettings
> The information of the GetProjectSettings response can be parsed by the
> client and used to generate an appropriate GetMap request with the
> correct layer order.
> Hope this helps,
> Andreas
> On 2021-03-31 18:07, 1520 gis wrote:
> Hi developers,
> I have tried to change the QGIS-Server layer order using QGIS Desktop
> Layers Panel and L.TileLayer.WMS (Leaflet) zIndex options. None of them
> could change the layer order. It seems that QGIS-Server always serves
> from bottom to Top: raster images, polygons, lines and points by
> default. Is there any way to change these settings?
> Kind regards
> Julierme
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210331/7d4436c0/attachment.html>
