[Qgis-user] Loading filtered database table as temp layer
    pathmapper
    pathmapper at posteo.de
    Tue May  4 03:16:44 PDT 2021
Hi Michael,
if it's just about creating a temporay layer as model output, you could
try to use the "Drop field(s)" algorithm after "PostgreSQL SQL execute
and load" in your model.
Just choose for the field "Input layer" the algorithm output of the
"PostgreSQL SQL execute and load" algorithm, leave the "Fields to drop"
field empty and enter a custom name for "Remaining fields".
You should also set a algorithm dependecy there (so the "Drop field(s)"
algorithm is executed after "PostgreSQL SQL execute and load").
This way the "Drop field(s)" algorithm doesn't remove any fields but you
get the option to create a tempory layer.
Hope this helps.
Bjoern
