[Qgis-user] Windows BATCH-File Start
Asmus
asmus.lists at gmx.de
Mon May 3 23:50:07 PDT 2021
Hi Bo,
thanks for the reply and sorry for answer so late.
That is exactly what I want to do and what doesn't work for me.
But now I have the trick, if I choose the option "capture output" on it works.
I don't know what this option do, I didn't used it before because I don't undestand what it is for, but it works.
If the option is on, no command window is open, but there opens a QGIS window which shows the output of the BATCH, and the work of teh BATCH will be done. Because of the missing command window, I thought it do not work.
Can anybody explain, what the option "capture output" do, and why the Windows BATCH do the work if the option is on, and don't do the work, if the option is off?
Thank you very much
Asmus
Am 28. April 2021 11:23:11 MESZ schrieb Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
>Hi, late to the party..
>However, this works on my Windows-10 64 bit / QGIS 3.18 64 bit:
>the "d:/tmp/start.cmd" contains only 1 line:
>@echo "%1"
>You should probably change the action type from "Open" to "Generic"
>Med venlig hilsen / Kind regards
>Bo Victor Thomsen
>Den 23-04-2021 kl. 13:40 skrev Asmus Harder:
>> Hi there,
>> I tried to use in QGIS 3.16 on Windows10 a old layer-action from QGIS
>> 2.18.
>> If I cklick on one object the action should start an BATCH-file and
>> gives some attributes as parameter to the batch-file. But it doesn't
>> work, nothing happens.
>> In QGIS2.18 it works fine.
>> If I use "Open" as type and only the BATCH-File without parameter
>than
>> the BATCH opens. If I add an parameter than nothing happens.
>> For example this work:
>> "d:\Test_Batch_Aufruf.bat"
>> but this doesn't work:
>> "d:\Test_Batch_Aufruf.bat" "Hello"
>> If I use a exe-file it works with a parameter.
>> For example this work fine:
>> "c:\Program Files\IrfanView\i_view64.exe" "D:\50342_col.tif"
>> Any idea why the BATCH-file doesn't start with parameter?
>> greetings
>> Asmus
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210504/0236f328/attachment.html>
