[Qgis-user] convex and concave areas
Azzurra Lentini
azzurralentini at gmail.com
Wed May 5 15:01:13 PDT 2021
Hi Stefan and Sebastian, thanks a lot for your suggestions.
Azzurra
Il mer 5 mag 2021, 15:30 Sebastian Gutwein <bas at rdgland.com> ha scritto:
> In the QGIS toolbox there is a Saga algorithm called Terrain Surface
> Convexity that does calculate convexity or concavity. I have never used it.
> http://www.saga-gis.org/saga_tool_doc/2.2.3/ta_morphometry_21.html
> https://sourceforge.net/p/saga-gis/discussion/354013/thread/3fadd3e7/
> On Wed, May 5, 2021 at 4:14 AM Stefan Giese (WhereGroup) <
> stefan.giese at wheregroup.com> wrote:
>> one process could be:
>> - smooth the DTM by a neigbourhood analysis. The width depends on the
>> size of your convex and concave areas. you can use a mean filter or lowpass
>> for example
>> - substract the filtered from the original
>> - select values > or < your cutoff
>> - convert this into polygons
>> see
>> https://www.researchgate.net/profile/Hazen-Russell/publication/277324326_A_semi-automated_esker_detection_method_EDM_for_improved_quantification_of_glaciated_landscapes/links/5567b6ca08aeab77721eac23/A-semi-automated-esker-detection-method-EDM-for-improved-quantification-of-glaciated-landscapes.pdf
>> for further reading
>> Hope this helps
>> Stefan
>> Am 05.05.2021 um 10:02 schrieb Azzurra Lentini:
>> Hi list,
>> I need to find the convex and concave areas from a dtm raster file. Do
>> you have any suggestions?
>> Thanks
>> Adjunct Professor University "Roma Tre"
>> Gis Applied for Environmental studies
>> Risk modelling & Hydrogeology
>> Consultant DFID-UK, United Nations, EU projects
>> AZZURRA LENTINI
>> Italy Mobile Tel.: **(39) 338 24 40 676
>> SKYPE azzurrahydro
>> *azzurralentini at gmail.com <azzurralentini at gmail.com>*
>> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> *
>> *Par respect pour l'environnement,*
>> *n'imprimez ce mail qu'en cas d'absolue nécessité*
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> Aufwind durch Wissen!
>> Web-Seminare und Online-Schulungen
>> bei der www.foss-academy.com
>> WhereGroup GmbH
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> Fon: +49 (0)761 / 519 102 - 61
>> Fax: +49 (0)761 / 519 102 - 11
>> stefan.giese at wheregroup.comwww.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210506/40b11e8c/attachment.html>
