[Qgis-user] Shapefile and GeoPackage
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed May 12 17:38:36 PDT 2021
Here are the geometry types for a geopackage https://www.geopackage.org/spec/#geometry_types
And you will find the geometry types for shapefiles here.
https://www.esri.com/content/dam/esrisites/sitecore-archive/Files/Pdfs/library/whitepapers/pdfs/shapefile.pdf
For lines or multiline... it’s the same for both. Limitations will be in the files size field names or field type that are more flexible in geopackage. But a line is a line, a polygon is a polygon... multiline and multipolygons the same. To my knowledge there is no difference. Maybe someone else will have a better information.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 12 mai 2021 à 18:13, Riccardo D'Alvito <r.chogan at hotmail.com> a écrit :
> Good evening.
> I would like some help regarding a difference between Shapefile format and GeoPackage format.
> In the creation of a Shapefile, in the choice of the type of geometry you have point, multipoint, line and polygon. In the creation of a GeoPackage in addition to these there are also multiline, multipolygon etc.
> So one can think that the Shapefile format does not support multiline and multipolygon geometries.
> But when, for example, working with a Shapefile of lines geometry, you can add parts to the lines by transforming the geometry from line to multiline.
> So my questions are the following:
> What is the difference between the multiline of the GeoPackage format (which can be set as geometry already in the creation of the layer itself) and the multiline of the Shapefile format (which derives from the creation of a file with basic geometry of lines)?
> Does the Shapefile format with multiline geometry (or multipolygons) have limitations compared to a GeoPackage with the same geometry?
> Thank you. I hope I was clear.
> A greeting,
> Riccardo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210512/0a91102e/attachment.html>
