[Qgis-user] Model Designer - Updating Field in Place
    Kirk Schmidt
    kirk at nortekresources.com
    Mon May 17 07:43:39 PDT 2021
Hi Ryan;
Yes, you would run a selection on then table first, apply the updates
and save. If you require interactive selection criteria, you can use a
number or string in input in your model. The user will then define them
when it is run.  Look under the vector selection Algorithms for select
and/or extract functions in the process modeler
Kirk Schmidt
On 5/17/2021 11:27 AM, ryanpeel wrote:
> Perfect!  It worked!
> And would you know how to set up model designer to have the model input to
> choose only selected rows versus whole table?
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
