[Qgis-user] Slooooow spatial joins
Karl Magnus Jönsson
Karl-Magnus.Jonsson at kristianstad.se
Tue May 18 04:15:43 PDT 2021
Hi!
How about just execute some SQL in an algorithm or model since you have the data in Postgis? And do the spatial join directly in the database. Like (not tested):
UPDATE polygonlayer p
SET p.field = pt.field
FROM pointlayer pt
WHERE st_within(pt.geom,p.geom);
Karl-Magnus Jönsson
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För Ryan Peel
Skickat: den 18 maj 2021 12:24
Till: Nyall Dawson <nyall.dawson at gmail.com>
Kopia: qgis-user <qgis-user at lists.osgeo.org>
Ämne: Re: [Qgis-user] Slooooow spatial joins
I can appreciate that but it forces to create another layer/file I think. I really don't want to have to re-import my entire table back into postgis just to get this one column.
On Mon, May 17, 2021, 10:29 PM Nyall Dawson <nyall.dawson at gmail.com<mailto:nyall.dawson at gmail.com>> wrote:
On Tue, 18 May 2021 at 11:59, Ryan Peel <ryanpeel at gmail.com<mailto:ryanpeel at gmail.com>> wrote:
> I have tried using MMQGIS plugin, refFunctions geomwith function and the aggregate function. I am using 3.18 QGIS
> Despite having spatial indexes on both tables, when I try to use any of these operations to assign the value of a field in the polygon layer to one in the point layer, it goes very slow. Like, ridiculously slow and of no value. And, I only have 600 records in the points layer and just a few thousand records in the polygon layer.
> What can I do to speed this up?
The absolute fastest way to join is to use the Processing tool: Join
Attributes by Location -- no plugins necessary :D
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210518/f1dc6eb0/attachment.html>
