On Wed, 19 May 2021 at 08:26, Grant Boxer <boxerg at iinet.net.au> wrote: > > I have had a query from a user - does QGIS uses multi cores during > processing? It depends on the particular algorithm you're running, but generally they will only use a single core. Nyall
