[Qgis-user] Geocoding with MMQGIS - Web service geocode
Charles Dixon-Paver
charles at kartoza.com
Thu May 27 14:12:42 PDT 2021
I recently tried the hqgis plugin which leverages the here api and it
seemed to work fine for my purposes. I used the free tier so your number of
API calls will be limited but if you are using above that you should
probably be using a commercial service anyway and you can just upgrade as
needed.
In terms of resolving the issues with mmqgis it may be worth sharing a
small sample set (even with incorrect/ dummy data but similar formatting)
and the specific configuration settings that are being used so that other
community members can more easily test and troubleshoot.
On Thu, 27 May 2021 at 22:19, Erich Purpur <epurpur at gmail.com> wrote:
> For what it's worth, Geocoding is one thing I have not found a good
> solution for in QGIS (including trying the MMQGIS plugin tool). In my
> experience, none of the geocoding plugins in QGIS work very well. I am
> lucky to have access to an ESRI license as well and do geocoding in ArcPro.
> I know that is not a solution for you, but if anyone else has a good
> geocoding solution in QGIS I'd love to hear it!
> -Erich Purpur
> On Thu, May 27, 2021 at 4:05 PM krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Hello,
>> I have a csv file with the columns "Address", "City", "State" and
>> "Country". I have 40 rows each row representing one address. All the
>> addresses are from the United States. I have the API key which I purchased
>> through subscription. For the web service option, I have chosen Google.
>> When I try to geocode, I am getting an empty shape file? Can anyone help
>> me fix this problem?
>> Regards.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210527/ed0ec05b/attachment.html>
