[Qgis-user] Atlas feature id not synchronised
Dario C
dario955i at gmail.com
Fri Nov 12 08:41:58 PST 2021
very helpful, thanks
any idea why @atlas_featureid start correctly (following layer coverage
feature) and then continue using odd numbers?
First values for ID field:
4,12, 38, 42, 60, etc
First values for @atlas_featureid:
4,12,38, 58, 72, etc.
Il giorno ven 12 nov 2021 alle ore 16:34 Alexandre Neto <
senhor.neto at gmail.com> ha scritto:
> $id is a function that returns the current layer row id. This id is
> somehow internal to QGIS and not actually a layer field.
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/functions_list.html#expression-function-record-and-attributes-id
> The @atlas_featureid is the equivalent for the coverage layer.
> So, if we are talking about the same layer then the two functions
> represent the same feature.
> Hope it clarifies.
> Alexandre Neto
> User Support
> www.qcooperative.net
> On Fri, Nov 12, 2021 at 2:39 PM Dario C <dario955i at gmail.com> wrote:
>> thank you for your quick response.
>> atlas coverage layer is the building layer
>> Yes, with $id = @atlas_featureid is working well!!! Thank you
>> Can you please explain, if you don't mind, why? I mean, what's
>> @atlas_featureid and why $id = @atlas_featureid solve the problem?
>> Il giorno ven 12 nov 2021 alle ore 15:04 Alexandre Neto <
>>> Hi Dario,
>>> If the atlas coverage layer is the buildings layer, then you can use:
>>> $id = @atlasfeatureid
>>> If not, if you have a common attribute called ID between the building
>>> layer and your coverage layer, you can use:
>>> "ID" = attributes( @atlas_feature)['ID']
>>> Hope it helps
>>> Alexandre Neto
>>> User Support
>>> On Fri, Nov 12, 2021 at 1:50 PM Dario <dario955i at gmail.com> wrote:
>>>> Hi,
>>>> I’m doing a report and it is happening something odd. I don’t know if
>>>> it a bug or something I’m not doing well (probably).
>>>> - I have a layer with an ID as integer and unique
>>>> - I have categorised my layer by rule, in order to show only the
>>>> analysed building: “ID=@atlasfeatureid+1”
>>>> - I’m using this ID as controller of my group report
>>>> - I have added a textfield to show some field and “atlasfeatureid+1”
>>>> for a double check
>>>> - first three pages are ok, after map and text are synchro, but the
>>>> categorised building does not work and indeed atlasfeatureid shows number
>>>> completely different with ID
>>>> I have no idea why :(
>>>> _
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211112/7da026b1/attachment.html>
