[Qgis-user] Print composer issue - QGis 3.22.00
Tony Shepherd (FarmMaps NZ)
tony at farmmaps.nz
Tue Nov 16 10:34:15 PST 2021
Hi Sebastien
I reported this bug back in 3.20 (July)
https://github.com/qgis/QGIS/issues/44426
To date, I have had no feedback as to confirmation of a bug or because of my doing, so in a way it is good to hear of a similar problem from another user.
While not a show stopper, it is extremely annoying and seems to be a worse problem in 3.22 than it was in 3.20. By that I mean the misalignment seems worse. In V3.20 zooming the layout to 100% seemed to fix the screen misalignment, in 3.22 it does not.
Questions:
Are you using label masks? If you disable them does your problem disappear?
Even though the display is not aligned, does printing or exporting an image produce correctly aligned output?
Cheers
Tony
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of CCM-S.RAYOT
Sent: Tuesday, 16 November 2021 11:02 pm
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Print composer issue - QGis 3.22.00
i,ve got a problem with raster layers on the print composer: there is a mismatch between raster layers and vector layers. i've checked the CRS, all seems to be normal.
Help!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211117/9d1df030/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211117/9d1df030/attachment-0001.png>
