[Qgis-user] Print composer issue - QGis 3.22.00
Tony Shepherd (FarmMaps NZ)
tony at farmmaps.nz
Tue Nov 16 16:22:39 PST 2021
Yes, but the error is also present if using only local raster files. So, the error is there no matter what type of raster I use (local or streaming). Simply disable label masking and the error resolves itself.
From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Sent: Wednesday, 17 November 2021 1:01 pm
To: Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
Cc: CCM-S.RAYOT <s.rayot at ccmatheysine.fr>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Print composer issue - QGis 3.22.00
Have you both been using wms server data, or other online data in your maps?
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 16 nov. 2021 à 13:35, Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz <mailto:tony at farmmaps.nz> > a écrit :
Hi Sebastien
I reported this bug back in 3.20 (July)
https://github.com/qgis/QGIS/issues/44426
To date, I have had no feedback as to confirmation of a bug or because of my doing, so in a way it is good to hear of a similar problem from another user.
While not a show stopper, it is extremely annoying and seems to be a worse problem in 3.22 than it was in 3.20. By that I mean the misalignment seems worse. In V3.20 zooming the layout to 100% seemed to fix the screen misalignment, in 3.22 it does not.
Questions:
Are you using label masks? If you disable them does your problem disappear?
Even though the display is not aligned, does printing or exporting an image produce correctly aligned output?
Cheers
Tony
From: Qgis-user <qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> > On Behalf Of CCM-S.RAYOT
Sent: Tuesday, 16 November 2021 11:02 pm
To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Print composer issue - QGis 3.22.00
i,ve got a problem with raster layers on the print composer: there is a mismatch between raster layers and vector layers. i've checked the CRS, all seems to be normal.
Help!
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211117/a9751bfd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211117/a9751bfd/attachment-0001.png>
