[Qgis-user] excel file with lat long
    Garth Fletcher
    garth at jacqcad.com
    Tue Nov 16 22:37:30 PST 2021
Be careful if you are using "DMS" format (42º17'35.123'') to use the
right symbols.
In my experience, using Mac OS X, option-zero for the degree symbol is
accepted, but option-k, which also makes a degree symbol, is not.
Similarly, "smart quotes", i.e., those which tilt, are rejected for
minutes, as are double quotes for seconds.
As long as you use the right symbols it works perfectly.  Of course if
you are using decimal degrees (42.123456) there is no problem.
Garth Fletcher
