[Qgis-user] Mars projection
    Lester Anderson
    arctica1963 at gmail.com
    Fri Nov 19 04:00:38 PST 2021
Hello,
I am trying to setup a custom projection for Mars using the WKT:
PROJCS["Mars_Equidistant_Cylindrical", GEOGCS["Mars 2000",
DATUM["D_Mars_2000",
SPHEROID["Mars_2000_IAU_IAG",3396190.0,169.89444722361179]],
PRIMEM["Greenwich",0], UNIT["Decimal_Degree",0.0174532925199433]],
PROJECTION["Equidistant_Cylindrical"], PARAMETER["False_Easting",0],
PARAMETER["False_Northing",0], PARAMETER["Central_Meridian",0],
PARAMETER["Standard_Parallel_1",0], UNIT["Meter",1]]
This is all fine and it validates ok.
What I need is to be able to use the Mars projection and be able to overlay
Longitude Latitude grid lines in layout, but I get no valid transform for
the default WGS84 etc. Anyone sorted out how this works?
Thanks
Lester
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211119/1cb56c21/attachment.html>
