[Qgis-user] Geo Raster Background
L.W. eaglelw at gmx.de
Fri Oct 1 01:36:58 PDT 2021
Thanks for answering, but I think this is not the way I want to go ...
Or, I do not have written detailed.
I have a raster image e.g. a white rectangle, after setting the points,
QGIS rotats this image, let's say, by 45 degrees.
The corners of the imported image are now black triangles.
I do want to have e.g. red triangles ...
Regards
Am 01.10.2021 um 09:50 schrieb Charles Dixon-Paver:
> There's not really any way for a GIS system to automatically
> differentiate between black background pixels and black data pixels.
> QGIS supports users setting custom pixel values to render as
> transparent pixels, but it's left up to users to ensure that their
> data and background values are different.
> From my view, there are a couple of options when it comes to fixing
> this issue in your data. One is to use an image processing tool like
> GIMP or Photoshop effectively, but that requires retaining the
> geographic information and knowing how to reprocess the raster
> accordingly.
> The simplest solution I'm aware of is probably to follow this workflow
> in QGIS:
>   * Start a new QGIS project
>   * Set all black pixels to transparent in the transparency tab of the
>     raster layer properties
>   * Digitize a "bounding area" - you can do this with a memory layer
>   * Move your vector layer to render underneath the raster
>   * Give the vector a simple black symbology
>   * Use the "Convert map to raster" tool from the processing toolbox
> There are a wide number of variations on that workflow that are
> possible of course, but I think that's the easiest to get started.
> Regards
> On Fri, 1 Oct 2021 at 09:28, L.W. <eaglelw at gmx.de
> <mailto:eaglelw at gmx.de>> wrote:
>     Hi,
>     how to change the backgroundcolor of a georeferenzed raster image?
>     When a raster image is rotated by qgis after setting all points the
>     backgroundcolor is black RGB(0,0,0).
>     Set black to transparent is difficult when there is black text.
>     regards
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/b1574c2e/attachment.html>
