[Qgis-user] Geo Raster Background
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Oct 1 04:41:40 PDT 2021
Perhaps you can add a file or a screen shot because what you want to do it not clear.  An image would help. In your second email, you talk about triangles?  Did you mean to write rectangles?
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 1 oct. 2021 à 05:30, L.W. <eaglelw at gmx.de> a écrit :
> I think one of us is on the wrong track with what is to be achieved.
> I don't want to manipulate the image itself, just the background at the moment when the raster image (or raster pdf) is converted to a TIF and georeferenced.
> if the rectangle contains black text, as described, this would also be manipulated after the described manipulation, that's not what I want.
> Thank you for your efforts.
> Am 01.10.2021 um 10:49 schrieb Charles Dixon-Paver:
>> You can translate pixel values with the raster calculator (available under the raster menu). Black pixels will have a value of 0,0,0 on RGB bands and red pixels would have a value of 255,0,0 so it's just a matter of changing the values accordingly on those bands.
>> The raster calculator will contain an if expression in the next QGIS release, but if you're using an existing release you will have to use a bit of a quirky syntax to achieve that.
>> So if you select the red band and use an expression similar to ( "Image at 1" =  0 )  *  255 it should work. If you need assistance on raster calculator syntax gis stack overflow has a large number of Q&A on the topic.
>> If you need info on a particular pixel value at each band, just use the identify features tool (it works on rasters too).
>> Note that the previous statement about the GIS identifying valid data values from background pixel values still applies to the calculator.
>> On Fri, 1 Oct 2021 at 10:36, L.W. <eaglelw at gmx.de> wrote:
>>> Thanks for answering, but I think this is not the way I want to go ...
>>> Or, I do not have written detailed.
>>> I have a raster image e.g. a white rectangle, after setting the points, QGIS rotats this image, let's say, by 45 degrees.
>>> The corners of the imported image are now black triangles.
>>> I do want to have e.g. red triangles ...
>>> Regards
>>> Am 01.10.2021 um 09:50 schrieb Charles Dixon-Paver:
>>>> There's not really any way for a GIS system to automatically differentiate between black background pixels and black data pixels. QGIS supports users setting custom pixel values to render as transparent pixels, but it's left up to users to ensure that their data and background values are different.
>>>> From my view, there are a couple of options when it comes to fixing this issue in your data. One is to use an image processing tool like GIMP or Photoshop effectively, but that requires retaining the geographic information and knowing how to reprocess the raster accordingly.
>>>> The simplest solution I'm aware of is probably to follow this workflow in QGIS:
>>>> Start a new QGIS project
>>>> Set all black pixels to transparent in the transparency tab of the raster layer properties
>>>> Digitize a "bounding area" - you can do this with a memory layer
>>>> Move your vector layer to render underneath the raster
>>>> Give the vector a simple black symbology
>>>> Use the "Convert map to raster" tool from the processing toolbox
>>>> There are a wide number of variations on that workflow that are possible of course, but I think that's the easiest to get started.
>>>> Regards
>>>> On Fri, 1 Oct 2021 at 09:28, L.W. <eaglelw at gmx.de> wrote:
>>>>> Hi,
>>>>> how to change the backgroundcolor of a georeferenzed raster image?
>>>>> When a raster image is rotated by qgis after setting all points the
>>>>> backgroundcolor is black RGB(0,0,0).
>>>>> Set black to transparent is difficult when there is black text.
>>>>> regards
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211001/646ee6ab/attachment.html>
