[Qgis-user] FW: Couldn't load SIP module - Windows 10
Fred Perloff
fred at perloff.us
Sat Oct 2 11:35:26 PDT 2021
Thank you for your prompt and insightful replies!
I decided to clean the slate – I uninstalled Anaconda & OsGEO4w, and rebooted. The PATH was clear of any references to python(s) and there were no PYTHONPATH or PYTHONHOME variables.
I reinstalled Anaconda, and made sure that I did NOT add conda to PATH. I installed QGIS desktop 3.20 and started the program. I received a very similar error message to last time. Both QGIS and Anaconda write to “Python path,” though QGIS entries are first in order.
Have any other thoughts on how to obtain Python support in QGIS?
Fred
Couldn't load SIP module.
Python support will be disabled.
File "", line 1, in
File "C:\PROGRA~1/QGIS32~1.3/apps/qgis/./python\qgis\__init__.py", line 82, in
from qgis.PyQt import QtCore
File "C:\PROGRA~1/QGIS32~1.3/apps/qgis/./python\qgis\PyQt\QtCore.py", line 24, in
from PyQt5.QtCore import *
ImportError: DLL load failed while importing QtCore: The specified procedure could not be found.
Python version:
3.9.5 (tags/v3.9.5:0a7dcbd, May 3 2021, 17:27:52) [MSC v.1928 64 bit (AMD64)]
QGIS version:
3.20.3-Odense 'Odense', 495fbaec
Python path:
['C:/PROGRA~1/QGIS32~1.3/apps/qgis/./python', 'C:/Users/Fred/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python', 'C:/Users/Fred/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python/plugins', 'C:/PROGRA~1/QGIS32~1.3/apps/qgis/./python/plugins', 'C:\\ProgramData\\Anaconda3', 'C:\\ProgramData\\Anaconda3\\DLLs', 'C:\\ProgramData\\Anaconda3\\lib', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\win32', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\win32\\lib', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\Pythonwin', 'C:\\Users\\Fred\\Documents', 'C:\\Program Files\\QGIS 3.20.3\\bin\\python39.zip', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\DLLs', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\lib', 'C:\\Program Files\\QGIS 3.20.3\\bin', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\lib\\site-packages', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\lib\\site-packages\\win32', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\lib\\site-packages\\win32\\lib', 'C:\\PROGRA~1\\QGIS32~1.3\\apps\\Python39\\lib\\site-packages\\Pythonwin']
Sent: Saturday, October 2, 2021 1:12 AM
To: Richard Duivenvoorde
Cc: Fred Perloff; QGIS User
Subject: Re: [Qgis-user] Couldn't load SIP module - Windows 10
There shouldn't be any problems in using conda and osgeo4w side by side, they should both have isolated python environments.
If I remember well, during conda installation you are asked if you want to add conda to the PATH environment variable (can't remember the exact wording), you need to say NO. Otherwise conda python will be the default python on your machine.
I agree with Richard, don't mess with osgeo4w scripts or you will end up with with an even worst mess.
Alexandre Neto
A sábado, 2/10/2021, 08:32, Richard Duivenvoorde <rdmailings at duif.net> escreveu:
Hi Fred,
I think indeed the source of your problem is the mixing of different versions of python: the one in osgeo4w and the Conda one. When SIP is not loaded correctly, you will not have any python based stuff in QGIS (so no plugins and processing).
The osgeo4w scripts normally 'isolate' the (python) paths pretty good. If I'm correct by actually even clearing your own PATH variable (??)
But I think that Conda add's it's path's to your normal (python)path's (PATH or PYTHONPATH) variables.
For what I know you should not have to 'fix' things in the osgeo4w scripts, better to make sure your system PATH is not filled with PYTHONPATH's or python/bin dirs in PATH.
You could try to start the osgeo4w 'terminal' and check what the environment variables PATH and PYTHONPATH are there. If you see conda-paths in it, these should be removed (either by removing them from your environment (but then you have to 'fix' conda) or by clearing them in the osgeo4w bat files...
Hope this helps, regards,
On 10/2/21 1:14 AM, Fred Perloff wrote:
> Hi,
> After a fresh install of OSGeo4W network installer, I start QGISD Desktop. A python error box pops up with the error copied below. I close the error window and the program loads. However, if I click on plugins settings, I receive the error: No Python support detected.
> I suspect I know the source of the problem. I have installed Python from Anaconda. Anaconda uses an older version of Python and of qt. I modified C:\OSGeo4W\etc\ini\python3.bat by prepending %OSGEO4W_ROOT%\apps\Python39;%OSGEO4W_ROOT%\apps\Python39\Lib;%OSGEO4W_ROOT%\apps\Python39\Lib\site-packages; to PYTHONPATH. There's a curious mix of / and escaped \\ in the resulting path.
> How do I enable loading python __init__.py when the desktop starts?
> Thanks!
> Error window:
> File "", line 1, in
> File "C:\OSGeo4W/apps/qgis/./python\qgis\__init__.py", line 82, in
> File "C:\OSGeo4W/apps/qgis/./python\qgis\PyQt\QtCore.py", line 24, in
> Python version:
> QGIS version:
> Python path:
> ['C:/OSGeo4W/apps/qgis/./python', 'C:/Users/Fred/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python', 'C:/Users/Fred/AppData/Roaming/QGIS/QGIS3\\profiles\\default/python/plugins', 'C:/OSGeo4W/apps/qgis/./python/plugins', 'C:\\ProgramData\\Anaconda3', 'C:\\ProgramData\\Anaconda3\\DLLs', 'C:\\ProgramData\\Anaconda3\\lib', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\win32', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\win32\\lib', 'C:\\ProgramData\\Anaconda3\\lib\\site-packages\\Pythonwin', 'C:\\Users\\Fred\\Documents', 'C:\\OSGeo4W\\bin\\python39.zip', 'C:\\OSGeo4W\\apps\\Python39\\DLLs', 'C:\\OSGeo4W\\apps\\Python39\\lib', 'C:\\OSGeo4W\\bin', 'C:\\OSGeo4W\\apps\\Python39', 'C:\\OSGeo4W\\apps\\Python39\\lib\\site-packages', 'C:\\OSGeo4W\\apps\\Python39\\lib\\site-packages\\win32', 'C:\\OSGeo4W\\apps\\Python39\\lib\\site-packages\\win32\\lib', 'C:\\OSGeo4W\\apps\\Python39\\lib\\site-packages\\Pythonwin']
> OS version: Windows 10 Version 2009
> QGIS version: 3.20.3-Odense 495fbaec
> Qt version: 5.15.2
> Python version: 3.9.5
> Windows 10 Pro
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211002/9d8f801e/attachment.html>
