[Qgis-user] Configuring QGIS server on Ubuntu 20.4
Aguilar Bolivar, Rosa Aguilar (UT-ITC)
r.aguilar at utwente.nl
Sun Oct 3 03:39:37 PDT 2021
Dear Mats,
I empathize with your words as I was struggle for a while setting qgis server on apache (first in windows and later in Ubuntu).
Perhaps you can check this material for more information and step by step configuration:
https://github.com/elpaso/qgis3-server-vagrant/blob/master/docs/index.rst
Best regards,
Rosa
On Sep 30, 2021 8:25 PM, Mats Elfström <mats.elfstrom at giskraft.se> wrote:
Hi!
I am setting up a Geodata stack. I have installed PostgreSQL/Postgis and Geoserver under Tomcat9 and FME:d a lot of data to PostGIS. All is up and running.
Then I installed QGIS 3.20. No problems so far. Then I decided to try QGIS server as an alternative to Geoserver. But I am having trouble configuring QGIS server, or Apache2 rather.
Over the past 5-6 years, I have spent more time and energy than I care to mention trying to make QGIS server run on Windows servers. Asking for advice on those occasions, I have more than once got the advice to use Linux instead, since no QGIS developers really know Windows servers. And Linux would be much easier.
Fair enough. So now I am on Ubuntu, sudoing this and that and it works pretty well.
Apart from QGIS server. I find the same mess of incomplete or contradictory instructions. No wonder QGIS server is under-used.
If Linux(Ubuntu) is so simple, how come no one has put together a working script to configure and deploy QGIS server on a standard setup?
I am most disappointed, having spent yet 5 hrs that I will never get back on QGIS server.
Regards, Mats.E
[https://drive.google.com/uc?id=1sRHl_CnQrtHqnEvCnblOPhzklqxxeH5J&export=download]
GisKraft, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se<http://www.giskraft.se>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211003/01993a2f/attachment-0001.html>
