[Qgis-user] Configuring QGIS server on Ubuntu 20.4
Mats Elfström mats.elfstrom at giskraft.se
Mon Oct 4 02:57:59 PDT 2021
Hi Richard!
I should have mentioned that. The request you suggest gives a Not Found
response.
The request
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?service=WMS&request=getcapabilities
gives
*Project file error. For OWS services: please provide a SERVICE and a MAP
parameter pointing to a valid QGIS project file*
Doing that, like this
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/qgis/projects/my_12.qgz
I get the wanted XML file. I would like to query the catalogue instead of a
single project file.
And like I said, the same request is valid for QGIS desktop *on the same
machine*.
A similar request, using the DNS name for the server, from the outside
http://geonet.se/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/qgis/projects/my_12.qgz
gives a 404 not found response.
Not Found
The requested URL was not found on this server.
Apache/2.4.41 (Ubuntu) Server at geonet.se Port 80
*Conclusion*: QGIS Server is running behind the firewall but not accessible
from the outside, *which of course is the purpose for my concept*.
*Comment on other replies*: I am not saying that QGIS server is not ready
for production or immature. On the contrary, it seems well documented and
ready. I seem to recall that it also is OCG compliant and certified.
*But * I am saying that the instructions for installation and
configuration, particularly for the interaction between QGIS Server and the
http engine are insufficient and sketchy. Regardless of OS, apparently.
Regards, Mats.E
Den sön 3 okt. 2021 kl 02:01 skrev Richard Greenwood <
richard.greenwood at gmail.com>:
> On Sat, Oct 2, 2021 at 10:02 AM Mats Elfström <mats.elfstrom at giskraft.se>
> wrote:
>> Hi!
>> Let me just recuperate that the goal for QGIS server is to be used as a
>> map and data server for webmaps on MapStore and to be harvestable by
>> Geonetwork for a metadata catalogue. MapStore and Geonetwork are running on
>> another machine. QGIS server shall run on a Ubuntu machine, along with data
>> in PostGIS. The address for this machine is http://geonet.se
>> Essentially, I see QGIS Server as an equivalent to Geoserver but with
>> outstanding design capabilities.
>> Here comes a run-through of an attempt to install QGIS server on an
>> Ubuntu 20.4 system, using these instructions:
>> https://docs.qgis.org/testing/en/docs/server_manual/getting_started.html#installation-on-debian-based-systems
>> The first step is to install QGIS, according to this page
>> https://qgis.org/en/site/forusers/alldownloads.html
>> I opted to install qgis-server by adding that in the last command as
>> suggested.
>> No problems so far. Only, when returning to the first manual page, I see
>> that I probably should have installed the LTR version instead of 3.20. If
>> this is important, the user should be advised earlier, and instructed how
>> to get the LTR version. For this review I will continue with 3.20.
>> Next, the user is again advised to install qgis-server and optionally
>> python-qgis. The motive for this is rather unclear at this stage, but I
>> chose to install python as advised.
>> Testing the installation by calling the fcgi seems to give a correct
>> response, even if it differs from the two samples. Notice error code 302
>> for instance.
>> root at geonet:~# /usr/lib/cgi-bin/qgis_mapserv.fcgi
>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
>> variable.
>> variable.
>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>> environment variable.
>> "Loading native module /usr/lib/qgis/server/libdummy.so"
>> "Loading native module /usr/lib/qgis/server/liblandingpage.so"
>> "Loading native module /usr/lib/qgis/server/libwcs.so"
>> "Loading native module /usr/lib/qgis/server/libwfs.so"
>> "Loading native module /usr/lib/qgis/server/libwfs3.so"
>> "Loading native module /usr/lib/qgis/server/libwms.so"
>> "Loading native module /usr/lib/qgis/server/libwmts.so"
>> Content-Length: 0
>> Location: http:/index.json
>> Server:  QGIS FCGI server - QGIS version 3.20.3-Odense
>> Status:  302
>> Next, it is suggested that I download a QGIS project or ‘use your own’ so
>> I manually created the /home/qgis/projects/ folder, and then saved a simple
>> QGIS project file to the folder. By default, this was saved in the qgz
>> format.
>> Then an HTTP server is needed.
>> A note says *In the following, please replace localhost with the name or
>> IP address of your server.*
>> But localhost only appears in the string webmaster at localhost where it
>> probably does not matter. There is no other mention of localhost in the
>> configuration file.
>> I go on to install Apache, as I have never used NGINX.
>> *You can run QGIS Server on your default website*
>> This is probably what I would want to do, but I do not know how, so I go
>> on to create a virtualhost as instructed by the name qgis.demo. I make the
>> log and qgisserverdb folders as instructed and set their permissions. Then
>> I enable fcgid and the site qgis.demo. The last command advises to run
>> systemctl reload apache2, but the manual suggests systemctl restart
>> apache2. I do both just to make sure. Then comes a tricky part, adding the
>> virtualhost to the hosts file. After that operation, it contains this. Note
>> that the server IP address got two definitions. I am bothered by this.
>> 127.0.0.1   localhost
>> ::1         localhost ip6-localhost ip6-loopback
>> ff02::1     ip6-allnodes
>> ff02::2     ip6-allrouters
>> # Auto-generated hostname. Please do not remove this comment.
>> 206.72.203.32 geonet.se geonet
>> 206.72.203.32 qgis.demo
>> Calling
>> from within the server gives
>> *<ServerException>Project file error. For OWS services: please provide a
>> SERVICE and a MAP parameter pointing to a valid QGIS project
>> file</ServerException>*
>> This seems correct. However, there is a totally confusing note here.
>> *Remember that both the myhost.conf and /etc/hosts files should be
>> configured for your setup to work. You can also test the access to your
>> QGIS Server from other clients on the network (e.g. Windows or macOS
>> machines) by going to their /etc/hosts file and point the myhost name to
>> whatever IP the server machine has on the network (not 127.0.0.1 as it is
>> the local IP, only accessible from the local machine). On *nix machines the
>> hosts file is located in /etc, while on Windows it’s under the
>> C:\Windows\System32\drivers\etc directory. Under Windows you need to start
>> your text editor with administrator privileges before opening the hosts
>> file.*
>> What is myhost.conf and what should it contain? The rest is very strange.
>> My goal is to access QGIS server from the internet, using the
>> http://geonet.se address, looked up by DNS as usual. Not from ‘other
>> clients on the network’ and the *myhost *name. What would be the point
>> for this? Not surprising,
>> from the outside returns
>> *Not FoundThe requested URL was not found on this server.Apache/2.4.41
>> (Ubuntu) Server at geonet.se <http://geonet.se> Port 80 *
>> Doing just http://geonet.se returns the Apache2 Ubuntu Default Page
>> And here the show stops.
>>    - I might add that PostgreSQL and Geoserver are accessible from the
>>    outside, and Geoserver serves WMS to the Internet as expected. Port 80 is
>>    obviously open too.
>>    - I can also access QGIS server from QGIS desktop *on the same
>>    machine*, using http://qgis.demo as root. But I had to include a MAP
>>    request in the string, with a full path to the project file.
>> Conclusion: The missing piece of information seems to be how to make
>> Apache2 direct incoming requests to QGIS Server, OR how to configure QGIS
>> server to run as *your default website. *As all the rest depends on
>> this, it is a vital piece of information.
> Matts,
> I am not a qgis server user so I am not the best qualified to answer your
> questions, but it sounds like you probably have qgis server installed
> properly and your problems are with Apache. Does your Linux machine have a
> desktop (a GUI)? If so, in a browser enter:
> http://localhost/cgi-bin/qgis_mapserv.fcgi?service=WMS&request=getcapabilities
> and you will see an xml document if the request is successful. If you
> Linux machine is headless, in a shell enter:
>    curl "
> A default Ubuntu install with Apache makes /cgi-bin/* available to all
> hosts on that server if cgi and fcigd have been enabled.
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
*GisKraft*, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211004/67ae2fc2/attachment.html>
