[Qgis-user] QGIS 3.20 Crash
    Stefan Giese (WhereGroup)
    stefan.giese at wheregroup.com
    Wed Oct  6 07:12:53 PDT 2021
first go to Menu->Settings->User Profiles->open active profile folder
then go one folder up...you will see all the profiles. The profile.ini
shows your default profile which you can change
a profile folder looks like this one:
now you can copy things from one folder to the other...at the moment I
don't know a better way. We are working on a Profile manager plugin to
make this easier, which should be ready soon
Am 06.10.2021 um 16:05 schrieb Martin Bittens:
> Yes, it worked. Using the new profile QGIS did not crash. But...
> 1.) How do I get all my settings and plug-ins from the previous
> profile into the new one?
> 2.) How do I get QGIS running always with the new profile when I
> start-up?  Do I need to delete the old profile?
> Regards
> Martin
> Am 10/6/2021 um 10:36 AM schrieb Stefan Giese (WhereGroup):
>> Did you try it also with a new profile?
>> Just make a new prrofile and test it again: Menu->Settings->User
>> Profiles->New Profile
>> If QGIS don't chrashes again, then your user profile is corrupt...
>> Am 06.10.2021 um 15:28 schrieb Martin Bittens:
>>> Hello QGIS users.
>>> Since a couple of days QGIS 3.20 crashes when I am closing the
>>> program. The following crash report appears:
>>> Crash ID: 2bba35ac54ec3f66db08369439704d5a7beb5523
>>> <https://github.com/qgis/QGIS/search?q=2bba35ac54ec3f66db08369439704d5a7beb5523&type=Issues>
>>> Stack Trace
>>> GDALDestroyDriver : dal::GDALRasterDriver::deregisterGDALDrivers :
>>> dal::Client::~Client : calc::DataStorageId::setId : ::operator() :
>>> __crt_seh_guarded_call::operator(), &, > : execute_onexit_table :
>>> calc::vs2CsfVs : calc::vs2CsfVs : LdrpCallInitRoutine :
>>> LdrShutdownProcess : RtlExitUserProcess : ExitProcessImplementation
>>> : exit_or_terminate_process : common_exit : BaseThreadInitThunk :
>>> RtlUserThreadStart :
>>> QGIS Info
>>> QGIS Version: 3.20.3-Odense
>>> QGIS code revision: 495fbaec
>>> Compiled against Qt: 5.15.2
>>> Running against Qt: 5.15.2
>>> Compiled against GDAL: 3.3.1
>>> Running against GDAL: 3.3.1
>>> System Info
>>> CPU Type: x86_64
>>> Kernel Type: winnt
>>> Kernel Version: 10.0.19043
>>> Any idea what is going wrong?
>>> Regards
>>> Martin
>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
>>> 	Virus-free. www.avast.com
>>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
>>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> Schon gewusst?
>> In unserem Blog geben wir Tipps & Tricks zu
>> Open-Source-GIS-Software und berichten aus unserem Experten-Alltag:
>> https://wheregroup.com/blog/
>> WhereGroup GmbH
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> Fon: +49 (0)761 / 519 102 - 61
>> Fax: +49 (0)761 / 519 102 - 11
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
Stefan Giese
Schon gewusst?
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211006/55e964f5/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211006/55e964f5/attachment.png>
