[Qgis-user] Python error upon loading and in every project
David Addy davesgrandad at gmail.com
Sun Oct 10 01:49:58 PDT 2021
I have not needed to consult the QGIS users Mailing List for some time, but
after changing my computer I had an issue with loading 3.16.11 to the new
machine. Upon opening an existing project QGIS  omitted to display the
thumbnails of recent projects and flagged an issue with Python. If anyone
can throw any light on how to fix this I would be very grateful.
Python Error an error has occurred while executing Python Code. See message
log for details.
STACK LIST
IndexError: list index out of range
  File
"C:\PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./python/plugins\processing\script\Sc
riptAlgorithmProvider.py", line 112, in loadAlgorithms
    folder = ScriptUtils.resetScriptFolder(folder)
  File
riptUtils.py", line 114, in resetScriptFolder
    commonSettingPath = os.path.join(paths[appIndex], paths[profileIndex])
Python version: 3.9.5 (tags/v3.9.5:0a7dcbd, May  3 2021, 17:27:52) [MSC
v.1928 64 bit (AMD64)]
QGIS version: 3.16.11-Hannover Hannover, 26cc1c76
Python Path:
C:\Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\To
mBio
*                     C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./python
C:/Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
*                     C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./python/plugins
*                     C:\Program Files\QGIS 3.16.11\bin\python39.zip
*                     C:\PROGRA~1\QGIS31~1.11\apps\Python39\DLLs
*                     C:\PROGRA~1\QGIS31~1.11\apps\Python39\lib
C:\PROGRA~1\QGIS31~1.11\apps\Python39\lib\site-packages
C:\PROGRA~1\QGIS31~1.11\apps\Python39\lib\site-packages\win32
C:\PROGRA~1\QGIS31~1.11\apps\Python39\lib\site-packages\win32\lib
C:\PROGRA~1\QGIS31~1.11\apps\Python39\lib\site-packages\Pythonwin
C:\Users\daves\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\Di
gitizingTools\tools
gitizingTools
C:\Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qg
is_resource_sharing
C:\Users\daves\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\qg
is_resource_sharing
is_resource_sharing\ext_libs
LOG
2021-09-28T16:15:33     WARNING    dir =
C:/Users/daves/AppData/Roaming/QGIS/QGIS3/profiles/default/python/plugins/Di
gitizingTools
2021-09-28T16:15:40     INFO    Application state:
             QGIS_PREFIX_PATH env var: C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr
             Prefix: C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr
             Plugin Path: C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/plugins
             Package Data Path: C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/.
             Active Theme Name: default
             Active Theme Path:
C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./resources/themes\default\icons/
             Default Theme Path: :/images/themes/default/
             SVG Search Paths:
C:/Users/DJAddy/AppData/Roaming/QGIS/QGIS3\profiles\default/svg/
              D:/My Pictures/QGIS Projects/Mapbox svg
icons/mapbox-maki-6.2.0-0-ga6d16d4
              C:/PROGRA~1/QGIS3~1.10/apps/qgis/./svg/
              C:/PROGRA~1/QGIS3~1.10/apps/qgis-ltr/./svg/
              C:/PROGRA~1/QGIS3~1.16/apps/qgis/./svg/
              C:/PROGRA~1/QGIS3~1.16/apps/qgis-ltr/./svg/
              C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./svg/
C:/Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/svg/
             User DB Path:
C:/PROGRA~1/QGIS31~1.11/apps/qgis-ltr/./resources/qgis.db
             Auth DB Path:
C:/Users/daves/AppData/Roaming/QGIS/QGIS3\profiles\default/qgis-auth.db
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211010/a76db621/attachment-0001.html>
