[Qgis-user] extracting vertices from a multipolygon using Field Calculator Function Editor
    Zoltan
    zoltans at geograph.co.za
    Mon Oct 18 23:36:25 PDT 2021
Thank you Stefan,
I knew it would be as simple as that, but could not find it (the 'Java
style' in the QgsGeometry class must have made me skip experimenting
with that )
In Afrikaans (I am South African/Hungarian) there is a saying:  'As jy
dom is, moet jy ...xxx'  -  and that was applicable to me in this case :-)
I wrote the script yesterday in a freestanding (PyCharm) environment to
solve the issue, as I needed to 'get it done', but this info is useful
for future.
Yesterday was the first time I was trying out the function editor and,
just btw, a week or two back was when I first started writing QGis
python scripts to solve work issues.
So yes, I am struggling to find 'what is where' even though I am 10's of
years down the road picturing the algorithm needed to solve my issue.
My current challenge is also QGis Atlas with multiple sub-maps per page
- but I am 'getting there' with some pointers received from this list.
Thanks again for your response.
Kind regards,
Zoltan
On 2021-10-19 08:14, Stefan Giese (WhereGroup) wrote:
> as a starting point:
> /from qgis.core import *//
> //from qgis.gui import *//
> //@qgsfunction(args='auto', group='Custom', referenced_columns=[])//
> //def zCutBox(feature, parent)://
> //    Calculates vertices and return the x coordinate of the first as
> string//
> //    geom = feature.geometry()//
> //    vertices = []//
> //    for v in geom.vertices()://
> //        vertices.append(v)//
> //    return str(vertices[0].x())/
> Am 18.10.2021 um 13:42 schrieb Zoltan:
>> Hi Listers,
>> I can't for the life of me work out the syntax/commands to use in the
>> FieldCalculator->FunctionEditor for extracting vertices.
>> I have a Polygon layer with Multipolygon rectangles at various rotations.
>> I need to extract the 4 corner points so that I can calculate (and
>> save in a virtual layer) lines that I can later use with
>> "Processing->Split with lines".
>> I will google for opening a new virtual layer and saving lines to it,
>> but if that is quick and easy then some help there would also be welcome.
>> Please can someone point me to a sample functions covering these
>> requirements, or just fill in the gaps below.
>> No, I'm not asking for someone to just write it for me.
>> Thanks in advance,
>> Zoltan
>> [Having a brain-dead day :-(  ]
>>         vertices =
>>         blah blah
>>         return vertices[0][0]
>> Zoltan Szecsei GPrGISc 0031
>> Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> Cape Town, South Africa.
>> Mobile: +27-83-6004028 (Signal, not WhatsApp)
>> www.geograph.co.za
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu
> Open-Source-GIS-Software und berichten aus unserem Experten-Alltag:
> https://wheregroup.com/blog/
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
Geograph (Pty) Ltd.
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211019/adae55e3/attachment.html>
