[Qgis-user] When running a Custom Function, the return value is different from when stepping through it and watching the 'Preview' value in Field Calculator
Zoltan
zoltans at geograph.co.za
Tue Oct 19 23:09:53 PDT 2021
Oh "for Pete's sake". - I'd love someone to explain why that is needed
and not auto-turned on or defaulted to True.
Thank you for bringing my attention to that tidbit.
Kind regards,
Zoltan
On 2021-10-19 19:07, DelazJ wrote:
> Hi Zoltan,
> You are playing with geometry so you need usesgeometry=True in your
> function decorator.
> See
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/expression.html#function-editor
> or the help section in the Function Editor tab.
> Regards,
> Harrissou
> Le mar. 19 oct. 2021 à 18:33, Zoltan <zoltans at geograph.co.za> a écrit :
> Hi,
> Me again :-(
> I've written a custom function in Field Calculator and want to put
> its return value into a new Text field in the attribute table.
> When I step through the features I get the correct and expected
> values shown next to 'Preview'
> But
> when I click OK to run the Field Calculator, it runs for a long
> enough time, auto-closes on completion and in the attribute table
> the new field is created, but value is 'Nothing for None' for all
> features.
> *Note:* variable rd_at reflects correct contents when stepping
> through and observing 'Preview' but seems to revert to Nonetype
> when running the function.
> What am I missing regarding using custom functions?
> Is it an intended thing that the Field Calculator auto-closes
> after running a custom function?
> Thanks again,
> Kind regards,
> Zoltan
> *Note:* The msg variable was introduced in case placing 'return'
> in various lines in the script was causing problems. I have also
> made the script below "more pedantic" to try and debug it.
> from qgis.core import *
> from qgis.gui import *
> import processing
> @qgsfunction(args='auto', group='Custom', referenced_columns=[])
> def del_cutboxes(feature, parent):
> geom = feature.geometry()
> attr = feature.attributes()
> rd_at = str(attr[5])
> lyr_rcl =
> QgsVectorLayer('Z:/Projects/RCL_boxes.shp','lyrrcl','ogr')
> rcl_feats = lyr_rcl.getFeatures()
> msg = ''
> for rcl_feat in rcl_feats:
> if len(msg) == 0:
> rclbox = rcl_feat.geometry()
> if rclbox.contains(geom):
> if rcl_feat.attributes()[0] is not rd_at:
> #feature.delete()
> msg = 'ToDelete ' + rd_at
> else:
> msg = 'ToKeep ' + rd_at
> if len(msg) == 0:
> msg = 'Nothing for ' + rd_at
> return msg
> Zoltan Szecsei GPrGISc 0031
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> Cape Town, South Africa.
> Mobile: +27-83-6004028 (Signal, not WhatsApp)
> www.geograph.co.za <http://www.geograph.co.za>
> Qgis-user mailing list
Geograph (Pty) Ltd.
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211020/bf214580/attachment.html>
