[Qgis-user] Line dissolve
Andrea Giudiceandrea
andreaerdna at libero.it
Wed Sep 1 00:33:28 PDT 2021
Nicolas Cadieux Mon, 30 Aug 2021 03:56:22 -0700
> This post explains what I would like. It offer a QGIS 2 script that could
> help.
> https://gis.stackexchange.com/questions/198317/join-merge-lines-that-touch-and-intersect-in-qgis
Hi Nicolas,
I've also successfully ported that script to QGSI 3 as a processing script.
Since it appears the script was originally published on StackExchange by
Jochen Schwarze, it has an implicit cc-by-sa license not really suitable
for software code...
I'm trying to contact the author as a courtesy to know if he wants to
publish himself the code with a GPLv2+ license on a collaborative
version control website, maintain it and eventually let it available on
plugins.qgis.org so I can submit my changes to him...
Anyway, you can find a version of the code modified by me to work as a
processing script in QGIS 3.
It adds a subnet field to a line type layer. The field will contain the
same unique progressive integer value for all the feature that are not
disjoint (i.e. having any common node or are intersecting) to the other
features.
You will find it at
https://gist.github.com/agiudiceandrea/621e4f0f2804e49cbd6f2a4314c0e482
Be aware that for now the processing script doesn't have a proper
progress and cancel feedback mechanism or any other sophisticated error
checking and handling and I don't know what its performance is with
layers containing a lot of features...
Regards.
Andrea
