[Qgis-user] Profile tool doesn't work on my MacBook Pro?
Joyce Hoed
j.hoed at icloud.com
Fri Sep 3 08:43:06 PDT 2021
Hi Peter,
Thanx for helping. I am hoping that you can help to find a solution. Making profiles is one of the main reasons for me to use Qgis. I really hope the bug can be fixed.
Kind regards,
Joyce
Verstuurd vanaf mijn iPhone
> Op 3 sep. 2021 om 16:53 heeft Peter Petrik <peter.petrik at lutraconsulting.co.uk> het volgende geschreven:
> Hi,
> I can confirm on the other project (crayfish) the same problem related to pyqtgrapth (both 0.11 and 0.12 versions) with EXC_CRASH (SIGABRT) in PyEval_SaveThread. I am investigating it, but it wouldn't be easy to debug....
> P.
>> On Fri, Sep 3, 2021 at 1:19 PM Peter Petrik <peter.petrik at lutraconsulting.co.uk> wrote:
>> Hi, with shut down you mean it crashes? If yes, does it produce a crash stack trace?
>> Peter
>>> On Fri, Sep 3, 2021 at 1:16 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>>> Hi,
>>> I don’t know what is going on. I would create a new user profile and try again. You could directly contact the programmers. You should find the info on the plugin page. https://plugins.qgis.org/plugins/profiletool/
>>> Nicolas Cadieux
>>> https://gitlab.com/njacadieux
>>>>> Le 3 sept. 2021 à 07:01, Joyce Hoed <j.hoed at icloud.com> a écrit :
>>>> Hello,
>>>> Can anyone help me out. I am a new user of QGIS and I want to use the profile tool for civil work purposes. I installed the latest version of QGIS on my MacBook Pro (specs below):
>>>> 2,3 GHz 8-Core Intel Core i9
>>>> 16 GB 2400 MHz DDR4
>>>> Radeon Pro 560X 4 GB
>>>> Qgis works, but every time I try to use the profile tools the program automatically shuts down? I try tho install en re-install the plug in but it doesn’t make any difference. Can someone help me out with this problem?
>>>> Kind regards,
>>>> Joyce
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210903/8d625f24/attachment.html>
