[Qgis-user] Build error on Debian testing 'bookworm'
Richard Duivenvoorde rdmailings at duif.net
Fri Sep 10 00:49:57 PDT 2021
Hi Piet,
I'm on bookworm too, and just successfully rebuild QGIS.
My best guess: something old in your build dir.
So I would try to create a fresh build dir and do a fresh rebuild.
Regards,
On 9/10/21 7:13 AM, APM wrote:
> Dear List,
> if I try to compile Qgis 3.20 on a Debian testing, the build failed with:
> [ 49%] Automatic MOC for target qgis_weakrelationtest
> [ 49%] Built target qgis_weakrelationtest_autogen
> Traceback (most recent call last):
>   File "/usr/bin/sip5", line 33, in <module>
>     sys.exit(load_entry_point('sip==5.5.0', 'console_scripts', 'sip5')())
>   File "/usr/bin/sip5", line 25, in importlib_load_entry_point
>     return next(matches).load()
> StopIteration
> make[2]: *** [python/CMakeFiles/python_module_qgis__core_autogen.dir/build.make:761: python/core/sip_corepart0.cpp] Fehler 1
> make[2]: *** Datei „python/core/sip_corepart0.cpp“ wird gelöscht
> make[1]: *** [CMakeFiles/Makefile2:7451: python/CMakeFiles/python_module_qgis__core_autogen.dir/all] Fehler 2
> Kind regards
> Piet
> Qgis-user mailing list
