[Qgis-user] On the capabilities of QGIS
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Sun Sep 19 16:58:05 PDT 2021
Not sure what the resolution is but you could start with Naturel Earth Data.  I’m sure there must be other finer databases out there and others will probably give you better answers.  This one is, for the very least, convenient.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 19 sept. 2021 à 08:02, Prvt Rsrchr | Jennifer Cluse <jencluse at iinet.net.au> a écrit :
>  G'day there, all,
> QGIS just discovered. Oh. Wow.
> Jennifer of Chermside Oz here, with two questions of a very generic nature. Sorry.
> Before I commit a big slice of my remaining life-span trying to mistress GIS via Q, can I ask:
>     1/ is Qgis in tandem with any known DB capable of providing me an accurate fine-grained result on the area of just the oceans, all of them, 360° round, that lie between the ancient Greeks Tropic zone, in my case either ±45° lat or ±50°. It's the granularity that I need.  (2° grid good, tighter ideal.)
>     2/ if Yes, what would be your rough assessment of the time it would take for this tech-head, in Mac since Syst 0.9 ancient crone, who is not fluent in any code or  language to pull out an answer, or
>     3/ again if Yes, and faster, is anyone willing to give this poor pensioner (cue the strings & harps) a price on your digging out this data?
> This because I believe that after 20 years of head scratching after the shock of first seeing the 200 year plot of CO2 in the atmosphere, and being an old radio tech recognizing a +ve feedback curve, think that with my 5th concept (four failures) I've gotten a winner that should stop ocean heating.
> Reflecting enough incoming insolation back out to level the EEI, and perhaps even reversing the heat build up. All done with 98% reflective buoys launched at strategic points onto passing currents, so they stay mostly in the Tropic zones. I need a scientifically valid referable source of accurate areas data to calc how many bouys are needed. All CC & open source, so not much followup cash flow.
> Hope someone can see a solution. Short of measuring my old 300mm inflatable home globe!
> Google Earth has proved accurate to establish gross areas (+0.3%, my measuring, 10° x 10° grids.)
> Need far better info, so as to not be dismissed out of hand.
> Cheers
> Jen
> Ms Jennifer Cluse  35 Reinhold Cres  Chermside  Qld  4032  Australia  UTC+10
> t:  07 3359 5352 (msg)  Intl: +61 7 3359 5352   m:  0447 400 470   e:  jencluse et iinet + net & au
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210919/b64df6a8/attachment.html>
