[Qgis-user] How make reading from protocol to use /vsicurl_streaming/ instead of /vsicurl/?
    Even Rouault
    even.rouault at spatialys.com
    Tue Sep 21 03:56:29 PDT 2021
Jukka,
Somewhat counter-intuitively, you can use
"https://api.digitransit.fi/routing/v1/routers/hsl/isochrone?fromPlace=60.168,24.938&mode=WALK,TRANSIT&date=2019-11-01&time=08:00:00&maxWalkDistance=500&cutoffSec=1800&cutoffSec=3600"
as a filename when using the File source type. This is due to GeoJSON
driver having a particular logic when passed a http[s]:// filename to
ingest it fully in memory.
Even
Le 21/09/2021 à 12:46, Rahkonen Jukka (MML) a écrit :
> Hi,
> This command gives a result with ogrinfo:
> ogrinfo
> /vsicurl_streaming/"https://api.digitransit.fi/routing/v1/routers/hsl/isochrone?fromPlace=60.168,24.938&mode=WALK,TRANSIT&date=2019-11-01&time=08:00:00&maxWalkDistance=500&cutoffSec=1800&cutoffSec=3600"
> -al
> If I try to use the URI part with QGIS with Add layer – Vector –
> Protocol – HTTP/HTTPS/FTP then QGIS seems to add automatically
> /vsicurl/ into the service request. With this service /vsicurl/ does
> not work but /vsicurl_streaming/ works. It there any way to force QGIS
> to use the streaming mode?
> The debugging tools do not seem to log the network traffic from the
> “read from protocol” requests. Is that a right observation?
> -Jukka Rahkonen-
> Qgis-user mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210921/b216ff92/attachment.html>
