[Qgis-user] Help with scales in print layouts for geographic CRS
    Greg Troxel
    gdt at lexort.com
    Wed Apr  6 07:10:17 PDT 2022
Patrick Dunford via Qgis-user <qgis-user at lists.osgeo.org> writes:
> On 6/04/22 11:34, Greg Troxel via Qgis-user wrote:
>> Jorge Gustavo Rocha via Qgis-user <qgis-user at lists.osgeo.org> writes:
>> 2) Using a geographic CRS, the same 150mm x 150mm map, at the same
>>> 1:10000 scale, the area is bigger then the 1500m polygon. The result
>>> is attached https://nextcloud.geomaster.pt/index.php/s/H2eAytsPANyxn6Y
>>> On both layouts the scale bar widget is working properly. The
>>> distances (and areas) are properly calculated in QGIS interface. I
>>> have set the GRS 1980 ellipsoid for distance and area calculations.
>> What does it mean to use a geographic CRS for a print layout?  Do you
>> really expect longitude on the x axis and latitude on the y axis?  The
>> value of meters/degree is different for x and y, unless you are at or
>> near the equator.  (Living at 42N-ish, I'm very aware of this.)
> This may be the case for projections like EPSG:3857 that are based on
> a spherical projection of the Earth but is it the case for all
> projections?
By "geographic CRS", I interpet that to mean one that is latitude and
longitude.  That is not really a "projection".
Yes, EPSG:3857 has an incorrect spherical assumption, and I'd have to
calculate, but I would not expect massive scale distortion, where
massive is casually visually apparent.
Perhaps Jorge can be precise about which CRS codes are in use.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220406/183865a5/attachment.sig>
