[Qgis-user] Issues with SAGA's tools
Kirk Schmidt kirk at nortekresources.com
Tue Apr 19 06:06:53 PDT 2022
Hi Lucas;
Try installing SAGA as a stand alone and run the tool.  I use this tool
regularly and it works fine.
Kirk Schmidt
On 4/19/2022 8:58 AM, Lucas Pomares via Qgis-user wrote:
> Hello,
> I’m trying to use fill sinks tool (Wang & Liu) of SAGA in Qgis
> Toolbox. However, when the process ends the program fails and doesn´t
> generate the result layers. I´ve tried it using different versions of
> Qgis (3.16 , 3.20 and 3.24) but I couldn´t solve the problem. SAGA
> version is 7.8.2. I also tried to uninstall and reinstall the program
> and I didn´t achieve.
> I tried to solve it by myself but I don´t know where is the problem
> and would want to ask if anyone knows how to solve it.
> I attach a picture of the fail and the log file in txt.
> In English says that:
> The following layers doesn´t generate correctly.
> C:/Users/Lucas/AppData/Local/Temp/processing_vRdlpU/1ee9a17ddce54df9967efcee956d7b95/FDIR.sdat
> C:/Users/Lucas/AppData/Local/Temp/processing_vRdlpU/83bae0d547e5462290b9d6530fb03bf3/WSHED.sdat
> C:/Users/Lucas/AppData/Local/Temp/processing_vRdlpU/a7ad2897f43e4c7bbfff4898a4a2cc07/FILLED.sdat
> You can look the << register message panel>> in main window of Qgis
> for more information about algorithm.
> Thank for the help!!
> *Lucas Pomares Zambrano*
> *Dpto. Ingeniería*
> GEOLÉN
> Advertencia legal:
> *GEOLEN INGENIERIA S.L.,*CON CIF B41954124 y domicilio social en C/
> Séneca, 1  - Local 7 (Valencina de la Concepción) - Sevilla, le
> informa que es responsable del Tratamiento de datos de carácter
> personal, donde se incluyen sus datos, cuya finalidad es la Gestión de
> sus servicios, la relación administrativo-comercial o la relación con
> el personal a su cargo, que incluye o puede incluir el envío de
> documentación. Le informamos que podrá ejercer los derechos de acceso,
> rectificación, limitación del tratamiento y portabilidad de sus datos
> personales en la dirección indicada mediante escrito, concretando su
> solicitud y al que acompañe fotocopia de su Documento Nacional de
> Identidad. El envío de este email responde con la totalidad de la
> legislación vigente en materia de protección de datos de carácter
> personal y Ley de Servicios de la Sociedad de la Información.
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
26 Church Road
Sutherlands River, NS
B0K 1W0
Tel (902) 922.3607
Email:kirk at nortekresources.com
Web:www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220419/b15fc2fe/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220419/b15fc2fe/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220419/b15fc2fe/attachment-0001.jpg>
