[Qgis-user] Activating ESRI geodatabase (.gdb) write mode in QGIS, OGR2OGR or Python
    Saulteau Don
    sault.don at gmail.com
    Wed Apr 20 20:20:37 PDT 2022
I think in the osgeo4w installer you just have to install the gdal-filegdb
package for that driver.
Donovan
On Wed., Apr. 20, 2022, 18:11 Nicolas Cadieux via Qgis-user, <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I am in a bit of a bind.  I am basically trying to figure out a way to
> write some .shp file to a .gbd folder using the gbd drivers obtained
> from ESRI. I am not sure what file to copy and where.  I am tying to
> make this work with ogr2ogr at the dos command prompt but getting to
> work with a anaconda python environment would be nice.
> Can the ESRI File Geodatabase API also be used write to a .gdb file
> using QGIS?
> If you recently did this, I would appreciate some tips.
> I am on windows 10 using the OSGEO4W install with QGIS 3.24.
> https://gdal.org/drivers/vector/filegdb.html
> Thanks
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220420/f201f7e5/attachment.html>
