[Qgis-user] Insert Logo into the map composer
    Alexandre Neto
    senhor.neto at gmail.com
    Sun Apr 24 00:52:02 PDT 2022
If I am not wrong, I think you can simply drag and drop the jpeg file into
the layout.
Give it a try.
Alexandre Neto
User support
www.qcooperative.net
A sábado, 23/04/2022, 22:04, Nicolas Cadieux via Qgis-user <
qgis-user at lists.osgeo.org> escreveu:
> Select raster image
> On 2022-04-23 2:52 p.m., krishna Ayyala wrote:
> Thank you. But that popup window is not allowing me to navigate to any
> jpeg file. only option it has is svg image.
> Regards.
> On Fri, Apr 22, 2022 at 9:35 AM Nicolas Cadieux <
> njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> https://docs.qgis.org/3.22/en/docs/training_manual/map_composer/map_composer.html
>> You will see an Icon on the left (blue sky with a mountain). Or Add
>> Item/add picture.
>> Nicolas
>> On 2022-04-22 9:05 a.m., krishna Ayyala via Qgis-user wrote:
>> > Hello,
>> > I have a map in the map composer. How can I insert a logo which is a
>> > jpeg image into the map composer?
>> > Regards.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220424/c639567a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220424/c639567a/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220424/c639567a/attachment-0001.png>
