[Qgis-user] Write vector attribute table from pandas dataframe
Wouter Impens
wouter.impens at gmail.com
Sun Apr 24 06:32:48 PDT 2022
If you have a field to join on, you could export the dataframe to something
that is readable in QGIS like csv or xlsx
Greetings
Wouter
Op za 23 apr. 2022 om 19:34 schreef Nicolas Cadieux via Qgis-user <
qgis-user at lists.osgeo.org>:
> Hi Ming,
> The best thing would be to show your code and ask others how it can be
> optimized. I find that https://gis.stackexchange.com/ is the best place
> to do this but this user list definitely has some very competent
> programmers. Not being one of those competent programmers, I will just
> state that pandas and geopandas use a process called vectorization where
> the “for loop” is done for you.
> https://medium.com/analytics-vidhya/understanding-vectorization-in-numpy-and-pandas-188b6ebc5398
> This means that looping over elements in a dataframe can be MUCH slower
> than using vectorization. So basically, you need to figure out the right
> code and avoid “for loops“ when using dataframes.
> Hope this helps
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 22 avr. 2022 à 11:50, ming han via Qgis-user <qgis-user at lists.osgeo.org>
> a écrit :
> Hi everyone
> Is there an efficient way to copy data in a pandas dataframe to the
> vector attribute table?
> I am looping element by element, which is very slow.
> Thanks
> Ming
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220424/f227c70b/attachment-0001.html>
