[Qgis-user] QGIS Atlas Print dpi street names
Alexandre Neto
senhor.neto at gmail.com
Mon Aug 15 01:57:14 PDT 2022
Check the maptiler plugin, it provides vector tiles, which are a great
alternative raster tiles and don't degrate with dpi changes.
A segunda, 15/08/2022, 08:15, Phil Wyatt via Qgis-user <
qgis-user at lists.osgeo.org> escreveu:
> Hi Lars,
> If the background is a raster map (like OpenStreetMap) then no, you cant
> control the labelling. You would need to add a vector layer for the roads
> and then style the labels from that new layer.
> Cheers - Phil
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Lars
> Bendix via Qgis-user
> *Sent:* Sunday, 14 August 2022 9:55 PM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] QGIS Atlas Print dpi street names
> Hello,
> Thank you so much for your help!!!
> I would like to print polygon objects using the atlas print function with
> 300 dpi instead of 75 dpi. But as I realized, the street names look too
> small now. Is there a way to adjust the font size of the street names in
> the atlas print preview?
> Thank you!
> Lars
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220815/4a4c5adb/attachment.htm>
