[Qgis-user] mdal / mesh simple formats
Matt Boyd
mattslists at gmail.com
Thu Aug 25 00:41:05 PDT 2022
Hi QGIS people,
I asked something like this a couple of years ago, managed to find
some workarounds and now that I know a little more about what I'm
doing I could use a bit of help.
I've got some simple tin meshes that I'd like to drop into QGIS, they
get generated in a python modelling software I'm using.
The data all sits in a single hdf5 file, points with coordinates, the
cells which are just the indexes of 3 points, plus attributes for each
point. About the simplest mesh setup I can imagine.
I'm trying to find the simplest format that mdal supports with an
example dataset so I can make something similar. (ideally hdf5 so I
don't need to work out how to use anything new in python).
Any tips?
Thanks
Matt
