[Qgis-user] Listing GIS data in subdirectories
    John Zastrow
    br8kwall at gmail.com
    Mon Dec 12 09:40:23 PST 2022
Update: A fellow user replied directly to me and suggested the "Load Them
All" plugin. LTA provides the ability to load geodata (raster and
vector) from a directory tree into QGIS with rich filtering ability. It's a
terrific utility that I now love. I also found the built-in tool *Processing
Toolbox/Layer Tools/Export Layer(s) Information*, which creates a tabular
list of layers either loaded in QGIS or also from a directory tree, is
close to my need. They work together reasonably well. However, my first
roadblock is that I need to be able to document Esri File Geodatabases and
the latter tool ignores them even though ogrinfo can read them.
Hope this helps others.
On Fri, Dec 9, 2022 at 5:39 PM John Zastrow <br8kwall at gmail.com> wrote:
> I'm often presented with piles of geodata from a range of sources and then
> must characterize, categorize, prioritize, and otherwise process them into
> a coherent body of data. Is anyone aware of a plugin or script that could
> use something like ogrinfo/gdal to point at drive/directory tree and create
> a delimited file/table describing major file types of spatial data
> structured like the following?
> "ID", -- incrementing number
> "Feature Name", -- xyz.shp, or abc.tif
> "Driver name", -- Shapefile, FileGDB, Geopackage
> "Full Path", -- full path to file, including inside feature dataset
> "Geometry", -- point, line, poly, raster, etc.
> "Feature Count", -- number of vector features
> "Geographic Coordinate System Name",
> "Projected Coordinate System Name",
> "Horizontal Units",
> "North Bounding Coordinate",
> "East Bounding Coordinate",
> "South Bounding Coordinate",
> "West Bounding Coordinate",
> "Created Date", -- from file system?
> "Modified Date", --  OGRinfo seems to report something for the DBF in
> Shapefiles?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221212/fea79688/attachment.htm>
More information about the QGIS-User
