[Qgis-user] QGIS 3.22 - Geometry by expression howto
Francesco Pelullo
f.pelullo at gmail.com
Sat Dec 31 05:03:48 PST 2022
Hi all,
Just trying to use algorithm "Geometry by expression" in a model, It don't
works for me.
I created a new model with three inputs parameters:
1. Longitude (real)
2. Latitude (real)
3. Map layer (points).
My goal is to empty [3], memorie coordinate values in two project
variables (@long and @lat), then add a new feature at (@long , @lat)
position.
I suppose can use "Geometry by expression" but result Is <null>
My settings:
Input layer = using model input = [3]
Output geom type = Point
Z dimension and M values = No
Geometry expression= make_point(to_real(@long), to_real(@lat))
Modifief Geometry = temp layer
The result Is ever a null geometry.
@long and @lat are correctly created and updated every time i run model.
Map layer Is EPSG:4326
Ideas?
Best wishes to everyone
Francesco
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221231/00b125db/attachment.htm>
More information about the QGIS-User
