[Qgis-user] Labeling Lines with Bearings
Kirk Schmidt kirk at nortekresources.com
Thu Feb 10 05:09:24 PST 2022
Hi Springfield:
You can place the python code in the
C:\Users\User\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\scripts
folder on your local machine and then it will show up under scripts in
the processing toolbox.
Kirk Schmidt
On 2/10/2022 4:03 AM, Springfield Harrison wrote:
> Hello Everyone,
> Thanks very much for the suggestions.  The main_angle option seem to
> do the trick.
> I didn't try the Python code.  Not familiar with that side of things
> although it is probably simple enough.  Could not find the recipe for
> adding it to the plug-in list, which I presume is where it is supposed
> to go.
> Thanks again, very helpful…
> Cheers, Spring
> On 04/Feb/2022 07:10, Kirk Schmidt wrote:
>> Hi Springfield:
>> Sure it would , I have attached my little convergence tool. Just
>> create a point in the area where you want to know the convergence at
>> let her rip.  The vary last column is the convergence in minutes.
>> So, depending on what side of the central meridian of your coordinate
>> system you are, it will either be negative or positive. SO, I just
>> used it yesterday for and area that is east of the meridian, UTM
>> easting > 500,000,   therefore the resulting convergence was 22
>> minutes, which need to be subtracted from the grid north value to
>> obtain true north.  It is not a sophisticated workflow, but I only
>> require it intermittently.
>> I usually use NRCAN magnetic declination calculator (online) to
>> verify the magnetic declination for the day.  But it seems to be
>> offline. I convert everything to magnetic for field work and then
>> there are no mistakes due to declination calculations and settings.
>> Have fun
>> Kirk
>> On 2/4/2022 6:34 AM, Springfield Harrison wrote:
>>> Aha, thanks Kirk.  That's why my lines are not as I intended.  This
>>> probably affects making the lines with the Shape Tool.
>>> Yes, it seems to draw in grid north, angle_main reports in True DD.
>>> The map is 26907, UTM 7N.
>>> I calculated the difference between as drawn and as reported and
>>> used that to change the input figure.  It works OK, not exact as the
>>> convergence varies with longitude, I believe.
>>> Thanks Kirk . . . .
>>> Cheers, Spring
>>> On 03/Feb/2022 02:59, kirk wrote:
>>>> Sent from my Galaxy
>>>> -------- Original message --------
>>>> From: kirk <kirk at nortekresources.com>
>>>> Date: 2022-02-03 5:55 a.m. (GMT-04:00)
>>>> To: Springfield Harrison <stellargps at gmail.com>,
>>>> qgis-user at lists.osgeo.org
>>>> Subject: RE: [Qgis-user] Labeling Lines with Bearings
>>>> Hi Spingfield.
>>>> I use a little routine and the core if it is:
>>>> main_angle($geometry) which you can use in field calculator.
>>>> Note this will give you the azimuth in relation to grid north for
>>>> the coordinate system you are using.  For projections, you will
>>>> need to lookup or calculate convergence to get the adjustment to
>>>> true north.
>>>> Kirk Schmidt
>>>> Sent from my Galaxy
>>>> From: Springfield Harrison <stellargps at gmail.com>
>>>> Date: 2022-02-02 7:30 p.m. (GMT-04:00)
>>>> To: qgis-user at lists.osgeo.org
>>>> Subject: [Qgis-user] Labeling Lines with Bearings
>>>> Hello,
>>>> I need to put the line direction (azimuth) into a line label. Some
>>>> searching has not come up with anything.
>>>> Is there a way?  Thanks very much . . . .
>>>> Cheers, Spring
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Kirk Schmidt, MScF, BScF, RPF
>> General Manager
>> Nortek Resource Solutions Inc.
>> 26 Church Road
>> Sutherlands River, NS
>> B0K 1W0
>> Tel (902) 922.3607
>> Email:kirk at nortekresources.com
>> Web:www.nortekresources.com
General Manager
26 Church Road
B0K 1W0
Tel (902) 922.3607
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220210/2f340773/attachment.html>
