[Qgis-user] features saved to geoserver with swapped coordinates
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Wed Feb 16 23:21:24 PST 2022
In the "New WFS Connection" dialog there's a checkbox for "Swap ax
orientation" (or something similar, my QGIS is not in English right now).
Hope that helps!
Raymond
On 17-02-2022 08:17, emmexx wrote:
> One of the users who edits data of a geoserver instance reported the
> following:
> - she imported in qgis a gpx file
> - she copied the features to a wfs layer connected to a remote
> geoserver, the features were positioned correctly on the map
> - she saved the data
> When she checked the result on the site where the layer data are
> publicly available, she found out that the data from the imported gpx
> were not where they should've been.
> She run qgis and found the features from the imported gpx now were not
> in the correct position.
> I checked the coordinates of the features in the gpx files and of the
> imported ones and discovered that in geoserver the coordinates were swapped.
> The features in the gpx are in northern Italy (approx coordinates lat
> 46, long 11), those saved in geoserver are in the sea north of Somalia
> (approx. coords lat 11, long 46).
> I checked the settings of the layer, of qgis, of the gpx, but everything
> seems ok.
> I tried the same operations on another device and everything worked as
> expected.
> What should I check?
> Qgis 3.16.8-Hannover
> Windows 10 Version 2009
> Thank you
> 	maxx
> Qgis-user mailing list
