[Qgis-user] Virtual layers intolerably slow to calculate
Jonathan Schultz
jonathan at schultz.la
Sat Jan 1 20:00:15 PST 2022
Hello all,
I've been trying to build an atlas using a virtual layer as the coverage
layer. Because I need the map to be controlled by the atlas I need the
virtual layer to include the relevant geometry, which I fetch from a
geometry layer via a join. However once I do this the performance
becomes completely intolerable, ie over a minute to calculate the
virtual layer. I tried making sure the joins happened on indexed columns
and anything else I could think of to speed it up but it didn't seem to
help.
To give an idea of the size of my data, the two layers I need to join to
build the virtual layer contain 5061 and 32 records, and the resulting
virtual layer 5061 records.
By way of comparison I tried computing the same virtual layer using
PostGIS, without bothering to create indexes on the join columns, and it
took <300ms.
So I guess the work-around is to just use a temporary PostGIS table in
place of the virtual table. But this is rather disappointing.
Can anyone suggest what might be happening here or any cleaner
work-around for this problem?
Thanks,
Jonathan
