[Qgis-user] Custom preset format page for print layouts
Thomas Gratier
osgeo.mailinglist at gmail.com
Sun Jan 2 13:02:19 PST 2022
Hope the following will be more understandable from a non-coder
# Below tell you how many entries (QgsPageSize) are already present (A4,
A3, ...) before
print(len(pageSizeRegistry.entries()))
# To inspect content of first entry (was useful to understand was is
present in each QgsPageSize)
print(pageSizeRegistry.entries()[0].size)
print(pageSizeRegistry.entries()[0].displayName)
print(pageSizeRegistry.entries()[0].name)
You could run also run the following to see all infos for all preset formats
for entry in pageSizeRegistry.entries():
print("Size: ", entry.size)
print(f"EncodedSize: {entry.size.encodeSize()}")
print(f"DisplayName: {entry.displayName}")
print(f"Name: {entry.name}")
Testing after adding the part `pageSizeRegistry.add(...` show you have now
one more entry compare to before
Regards
Thomas
Le dim. 2 janv. 2022 à 21:16, Christophe Besuchet <design at golok.net> a
écrit :
> Hi Thomas,
> Thanks a bunch for your answer and your code. It works like a charm!
> However, I'm really bad at coding and I'm not sure why some lines are
> commented; since your code works without uncommenting these lines, can you
> tell me what's their purpose?
> Cheers,
> Golok
> On 2 Jan 2022, at 18:00, Thomas Gratier <osgeo.mailinglist at gmail.com>
> wrote:
> Hi,
> In startup.py, add the following to register your custom Custom preset
> format page for print layouts.
> from qgis.core import QgsApplication, QgsPageSize, QgsLayoutSize,
> QgsUnitTypes
> pageSizeRegistry = QgsApplication.pageSizeRegistry()
> # For demo purpose in PyQGIS, so commented
> # print(len(pageSizeRegistry.entries()))
> # print(pageSizeRegistry.entries()[0].size)
> # print(pageSizeRegistry.entries()[0].displayName)
> # print(pageSizeRegistry.entries()[0].name)
> # You will see in the menu, myDisplayName with other default preset format
> pages after executing the following line
> pageSizeRegistry.add(QgsPageSize('myname', QgsLayoutSize(150, 100,
> units=QgsUnitTypes.LayoutMillimeters), 'myDisplayName'))
> Cheers
> Thomas Gratier
> Le mer. 29 déc. 2021 à 19:50, Christophe Besuchet <design at golok.net> a
> écrit :
>> Hello all,
>> I'm often using the same custom page size in my print layouts, and I
>> created several templates for this.
>> However, if I have to add a new page, the later won't inherit my
>> template's format settings; the Size menu will only propose standard
>> presets and I will have to set the size manually (and the guides as well).
>> Is there a way to create and save custom preset format pages so they will
>> show up in the Size menu?
>> In advance thank you for your help!
>> Golok
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220102/70164b85/attachment.html>
