[Qgis-user] Wrong area count QGIS 3.20+?
Sadowski Jarosław jaroslaw.sadowski at cpk.pl
Sun Jan 2 23:57:48 PST 2022
Sebastian,
thank you very much for your precise answer and materials sent - I have read them carefully.
So, as far as I can understand, QGIS has moved in version 3.20 to a new way of counting areas (other libraries? GRASS algorithm instead of Geographic lib? I have actually noticed a different nomenclature and definition of EPSG 2180 for some time in new versions...), that will be more accurate?
I must admit that, for me as a GIS operator, it is surprising and sounds like bad news - so far surfaces have always been the same in various GIS software, whether or not it was open-source or commercial (ArcGIS Pro). So from this moment it will be that I will get different surfaces depending on the software it was calculated? :(
with kind regards
JS
_____________________________
Jarosław Sadowski
Ekspert ds. Baz Danych i Analiz Przestrzennych | Biuro Strategii i Planowania, Projektowania i Inżynierii Podprogramu Kolejowego
Database and Spatial Analysis Expert |Railway Subprogramme Strategy & Planning, Design & Engineering Department
e: jaroslaw.sadowski at cpk.pl<mailto:jaroslaw.sadowski at cpk.pl>
Sent: Saturday, January 1, 2022 7:13 AM
To: Sadowski Jarosław <jaroslaw.sadowski at cpk.pl>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Wrong area count QGIS 3.20+?
Nie otrzymujesz często wiadomości e-mail z adresu bas at rdgland.com<mailto:bas at rdgland.com>. Dowiedz się, dlaczego jest to ważne<http://aka.ms/LearnAboutSenderIdentification>
There was some discussion on this in the list serve back in January<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2F2021-January%2F047638.html&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bUHOuswrG6tPdkebzFYem%2BVsSrgjFhbSLVcKCiu6TW0%3D&reserved=0> that resulted in this feature request<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fissues%2F40888&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dY89NsDscjybmwQPMV9PjPOwckPlcv%2B8TEWjl69rTtM%3D&reserved=0> and this pull request<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fpull%2F41726&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IRMFsaJYT7xpylDJCZNvXAUNzdmtTjNbI4VyQMKtedE%3D&reserved=0>. I tested your polygon, to the best of my limited ability, and the areas were indeed different in QGIS 3.16 and 3.22 as would be expected from that change . However it would be hoped that the area measurement would be more accurate in 3.22.
On Fri, Dec 31, 2021 at 6:49 AM Sadowski Jarosław <jaroslaw.sadowski at cpk.pl<mailto:jaroslaw.sadowski at cpk.pl>> wrote:
Dear all,
I am asking for help with QGIS error/bug or verification of proper usage of basic QGIS functionality "$area".
>From version 3.20 upwards, it counts areas differently than before (3.18 calculated area is different than 3.20). Up to version 3.18 everything was fine, equal to calculations from ArcGIS Pro (geodesic mode).
Anyone have an idea where the differences come from?
This is example vector [cid:image001.png at 01D8007F.FA587F60]  PL_2180.zip<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcpkonline-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fjaroslaw_sadowski_cpk_pl%2FEVs0-TiEvPdBjMaqXrEvGfoBI0VussbJaYHdDVFfQnEYug%3Fe%3DVDY3rf-&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=JlPtyjeeYHQxV0DdlGrsPwjTNy9FHqqyEqEpLNrian8%3D&reserved=0>: Polish borders in EPSG: 2180, in the table of attributes you can see the areas (hectares) calculated for different versions of the software.
with wishes for more success in the new year
Jarosław Sadowski
_________________________________
Jarosław Sadowski
Database and Spatial Analysis Expert | Railway Subprogramme Strategy & Planning, Design & Engineering Department
m: +48 532 720 230
[cid:image002.png at 01D8007F.FA587F60]
Centralny Port Komunikacyjny Sp. z o.o. z siedzibą w Warszawie, Aleje Jerozolimskie 142B, 02-305 Warszawa; nr KRS 0000759991, Sąd Rejonowy dla m.st<https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fm.st%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oT4ox6NtPJ4TlAS2CTPM0KgLWAFOMUZ2O1N9EEE4Dfc%3D&reserved=0>. Warszawy, XII Wydział Gospodarczy Krajowego Rejestru Sądowego; NIP 701-08-94-497; REGON 381918620; kapitał zakładowy 1.277.500.000,00 zł
Administratorem danych osobowych przekazanych przez Panią/Pana m.in. w korespondencji mailowej jest Centralny Port Komunikacyjny Sp. z o.o. z siedzibą w Warszawie. Przetwarzamy dane osobowe zgodnie z przepisami ogólnego rozporządzenia o ochronie danych (RODO), więcej informacji na ten temat znajduje się w zakładce Polityka Prywatności oraz w Klauzuli informacyjnej na stronie internetowej www.cpk.pl<https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3nB3VJa54%2FlK17eCUR2bvwIusD0MYzQQ1MmbCmbh3Is%3D&reserved=0>.
Treści zawarte w niniejszej wiadomości i załącznikach do niej stanowią Tajemnicę Przedsiębiorstwa w rozumieniu ustawy z dnia 16 kwietnia 1993 r. o zwalczaniu nieuczciwej konkurencji. Jeśli otrzymałeś tę wiadomość przez pomyłkę, bezzwłocznie skontaktuj się z nadawcą wiadomości oraz usuń jej treść.
Solidarity Transport Hub Poland: Centralny Port Komunikacyjny Sp. z o.o. with headquarters in Warsaw, Aleje Jerozolimskie 142B, 02-305 Warsaw; KRS No. 0000759991, District Court for the Capital City of Warsaw, 12th Commercial Department of the National Court Register; NIP 701-08-94-497; REGON 381918620; share capital of PLN 1.277.500.000,00.
The personal data controller of the personal data provided by you, among others, in the e-mail correspondence, is Centralny Port Komunikacyjny Sp. z o. o. based in Warsaw. The personal data is processed by us in accordance with the provisions of the General Data Protection Regulation (GDPR), for further information please read the Privacy Policy tab and the Information Clause on the www.cpk.pl<https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3nB3VJa54%2FlK17eCUR2bvwIusD0MYzQQ1MmbCmbh3Is%3D&reserved=0> website.
The content of this message and its attachments constitute the Business Secret within the meaning of the Act of 16 April 1993 on combating unfair competition. If you received this message by mistake, contact the sender of the message immediately and delete its content
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oFJ%2FkA4lI5PPgPaEOLyh3jG3Cp49JqK0FQ7eTYd%2FOjM%3D&reserved=0>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oFJ%2FkA4lI5PPgPaEOLyh3jG3Cp49JqK0FQ7eTYd%2FOjM%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/a1aaaf27/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/a1aaaf27/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/a1aaaf27/attachment-0003.png>
