[Qgis-user] HTML Image Map
    Stefan Keller
    sfkeller at gmail.com
    Fri Jan  7 02:14:57 PST 2022
Am Fr., 7. Jan. 2022 um 08:42 Uhr schrieb Richard Duivenvoorde
<rdmailings at duif.net>:
> @stefan: do you still have use for your version?
No, not really.
I'm mainly using Tom's qgis2web plugin for those use cases
https://github.com/tomchadwin/qgis2web/wiki
Yours, Stefan
> Hi Nev,
> I'm the original author of the HtmlImageMap plugin (my earliest/first one, oct 2010): https://plugins.qgis.org/plugins/imagemap_plugin/
> Students of Stefan (in bcc) created a version with more advanced html and javascript:
> https://plugins.qgis.org/plugins/html-image-map-creator/
> Both are indeed only available for QGIS 2.x
> Are you sure you still want an ImageMap? I would say that for example saving your map to geojson and then use some simple Leaflet code would be more 2022 :-)
> Would that be possible? Or or there still a group of users which are avid html-image map believers?
> Because it would be a waste of time (to me) to port the old 2.x plugin to 3.x if nobody actually would use it...
> Regards,
> On 1/7/22 06:09, nwastra nwastra wrote:
> > Hi
> > I have a .gdb file with catchment boundaries of river regions and would like to create a html image map with the name of the catchment displaying on hovering over each catchment and on selection giving a link to a file of that waterway data to download.
> > I am using QGIS 3.22.2 and I can’t find a way to create a HTML imagemap.
> > I found HTML Image Map Creator QGIS-Plugin <https://github.com/geometalab/HTML-Image-Map-Creator-QGIS-Plugin> but Qgis gave an error message *This plugin is incompatible with this version of QGIS *Plugin designed for QGIS 2.14.16 - 2.99
> > Can QGIS 3.22 create an html image map or should I install 2.14 or is there another method?
> > Nev
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
