[Qgis-user] QGIS Modeling, using an model input layer name
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Jan 7 14:23:36 PST 2022
Thanks for you attention.  I was finally able using the following method:
Inputraster -> Export layer(s) information ->  Execute SQL (SELECT name
FROM input1) -> List unique values -> use the following expression in
the Field calculator @List_unique_values_UNIQUE_VALUES.  This gives me a
string of the layer name of the model input file.
Not easy... :)
Nicolas
On 2022-01-07 2:42 p.m., Nicolas Cadieux wrote:
> Hi,
> I'am not trying to use the field calculator on the raster.  I am
> trying to use the layer name of the raster as value.  This value then
> goes into the field calculator.  This is in a QGIS model.
> Hope this is clearer.
> Thanks
> Nicolas
> On 2022-01-07 2:07 p.m., Kirk Schmidt wrote:
>> Hi Nicolas
>> The field calculator will not process raster data.  Try using the
>> raster calculator
>> Kirk Schmidt
>> On 1/7/2022 2:56 PM, Nicolas Cadieux wrote:
>>> Hi,
>>> I can figure this on out!!!  I want to use the layer name of the
>>> input layer (a raster) as value for the field calculator.
>>> layer_property(@Inputraster , 'name')  does not work.  Any suggestions?
>>> Thanks
Nicolas Cadieux
https://gitlab.com/njacadieux
