[Qgis-user] QGIS Model Designer
Ujaval Gandhi ujaval at spatialthoughts.com
Tue Jan 11 06:21:59 PST 2022
The batch processing and modeler are mising the 'iterate' feature, and this
type of batch processing + merge functionality will be useful. I have a
tutorial on how to write a bit of pyqgis code to do this that shows exactly
the use case you have. But it can be used with any other processing
algorithm.
https://www.qgistutorials.com/en/docs/3/processing_algorithms_pyqgis.html
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Mon, Jan 10, 2022 at 4:52 PM Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi All,
> Apologies, but I think I have found a Plugin, which looks promising “Point
> sampling tool” which seems to do what I want.
> Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> *FRM Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Richard
> McDonnell
> *Sent:* 10 January 2022 11:18
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] QGIS Model Designer
> Hi all.
> I have been asked to sample over 100 raster pixel values using a single
> point file.
> I can use the “Sample raster values” Tool, but this only outputs for one
> Raster. I have looked at batching this, but it will produce 100’s of point
> files which I will have to merge together. So I was looking at using the
> Model Designer, but again it can’t accept multiple raster inputs.
> What I would like to know, is how I might easily create a single shapefile
> with a column for each raster containing the sampled value. The easiest way
> would be to somehow sample the first raster saving the output then loop
> back to the second raster, but this time using output from the first
> sampling to sample the second. This looping would continue until all
> raster’s had been sampled.
> Any help appreciated.
> Regards,
> Richard
> *Richard McDonnell MSc GIS, FME Certified Professional*
> *Oifig na nOibreacha Poiblí*
> *Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36 *
> https://gov.ie/opw
> Email Disclaimer:
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220111/59727772/attachment.html>
